Mystery Hood
Old Aug 25, 2023 | 08:36 AM
Loweralabama's Avatar
Mystery Hood
Hello:
Can anyone on here identify what hood this is? I have never seen one quite like this. I have seen low profile cowl and ram air but not a combination quite like this. They gentleman told me it came off of wrecked 442 but I have searched far and wide for this same hood and have not seen a pic yet showing the same hood. Please identify the year and or if you know this to be just a custom hood. If it is custom and you know the manufacturer please let me know. Thanks in advance for your help and cooperation.
Old Aug 25, 2023 | 08:41 AM
Fiberglass or steel?
Old Aug 25, 2023 | 08:49 AM
The gentleman said a factory steel 72 model hood. The car is an 86 so that doesn't jive. That is why I shared it on here to figure out what it really was. I sort of like it....unique.
Old Aug 25, 2023 | 09:30 AM
It's someones goofy home built rendition with 1978 Z28 hood incerts.
Old Aug 25, 2023 | 09:33 AM
70W-32's Avatar
Aftermarket or homemade. Never was on a production car
Old Aug 25, 2023 | 09:50 AM
Now that you mention it those Z28 inlets do look familiar and that makes sense. Thanks for the reply.
Old Aug 25, 2023 | 09:56 AM
GN1220's Avatar
The way it's bowed I would definitely say fiberglass. You might also mention to the guy giving you that information that he has no idea what he is talking about.
Old Aug 25, 2023 | 10:24 AM
Thanks for that information and reply.
Old Aug 25, 2023 | 10:36 AM
It's an aftermarket cowl induction hood that someone has cut out and added aftermarket NACA scoops to. You can get G-body cowl induction hoods in both metal and fiberglass, in a variety of scoop heights. The NACA scoops are available from a number of vendors in different sizes and configurations.
Old Aug 25, 2023 | 11:02 AM
That does look and sound like this particular application. Thanks for the reply and information.
Old Aug 25, 2023 | 01:14 PM
Wow, if those scoops are open and functional, then it's a "pass through" hood. The air comes in the front scoops and blows right out the rear cowl opening. Engineering Fail
Old Aug 25, 2023 | 02:25 PM
No offense to our particular new member, but the man IS in Lower Alabama, where this sort of thing occurs.
Old Aug 25, 2023 | 02:39 PM
crossboss's Avatar
Past owned:
An aftermarket made up cowl with some sort of '69-'70 Shelby NACA type of scoops attached.
Old Aug 28, 2023 | 06:10 AM
zl1 camaro's Avatar
That's a aftermarket for sure
Old Aug 28, 2023 | 10:14 AM
crossboss's Avatar
Past owned:
Absolutely agree! They should have installed the NACA scoops on the outer edges of the hood. At least that would have cooled the engine compartment....at least in theory that is.
Old May 30, 2025 | 03:18 PM
76455's Avatar
76 Cutlass Salon
I knew that looked familiar. And the more I look at it, all I see is a Camaro sneezing on a Cutlass.
crossboss
May 30, 2025 03:31 PM
Bigmikey65
Feb 6, 2023 03:38 PM
olds 307 and 403
May 3, 2018 01:12 PM
Rocketguy
Sep 12, 2016 07:02 AM
