Motor install
Old Jan 29, 2025 | 02:44 AM
Jamesbumble's Avatar
Motor install
So I am about to be installing a 350 small block back into a 77 Cutlass supreme that I took it out of a few months ago. The motor has since been shipped off to a machine shop and had all the pistons, rocker arms, cam shaft, all that redone. Is there anyone out there that has some helpful videos and or some advice as to a good place to start? I have to put all the pulley's and what not back on and I'm curious as to what should be put on now and what can wait. I have done a fair amount of wrenching in my time but this is the first time that I will be doing an install basically on mty own. Thank you for not being all judgy and what not.
Old Jan 29, 2025 | 04:22 AM
Bfg's Avatar
Bfg
If you removed the engine by yourself, hopefully you took some pictures and made notes of how things were removed, just assemble in reverse order. Do you have the Service manual?
Old Jan 29, 2025 | 04:26 AM
zl1 camaro's Avatar
There is plenty enough room to put everything on that engine before you install it, including the engine mounts & drive belt ETC... I would also suggest removing the torque converter and replacing the front pump seal at this time. When putting the converter back in put some grease on the hub surface & Spin the converter as you push it back into the front pump.you will hear 2 clicks as it goes back in. MAKE SURE IT IS FULLY SEATED. As far as the pulleys & brackets go it will come back to you as to how it goes. .If not, Joe probably has a manual as to how they go I bet... Good luck..
Old Jan 29, 2025 | 05:15 AM
Are the heads on the engine, or is it just the short block? You can easily install the heads after the short block is installed, but if everything is already together no need to disassemble anything for install.
Old Jan 29, 2025 | 08:42 AM
Easily install heads after the engine is installed?
Old Jan 29, 2025 | 09:58 AM
Bfg's Avatar
Bfg
My back is aching just hearing that statement
Old Jan 29, 2025 | 10:54 AM
I removed and installed the heads (56 lbs.) in my 71 98 with the short block in the car.
I've read it's quite difficult to remove the heads and install head studs on the 6.9l IDI diesel in my 86 Ford F250. You actually should use an engine hoist since the heads are so heavy (93 lbs.)
Old Jan 29, 2025 | 11:30 AM
Bfg's Avatar
Bfg
Work smart not hard
Old Jan 29, 2025 | 03:10 PM
First thing you need to do is get a factory manual. It will list all the critical bolt torque, and have detailed illustrations on how all the brackets go together.
When you’re ready to install bellhousing bolts, don’t just crank them down. Start the bolts, slowly tighten them evenly, and stop occasionally to make sure the torque converter still spins. If it locks up solid, immediately stop and find out why. More than likely the converter isn’t seated in the pump correctly, if you continue to tighten them with the converter not on correctly you can destroy the converter AND the pump, meaning transmission rebuild.
Coastie
Mar 4, 2020 01:17 PM
Southern_Hospitality
Oct 12, 2011 08:01 AM
td2000
May 20, 2009 07:33 PM
Sedrick
Mar 19, 2009 06:13 AM
xxibishn
Sep 14, 2006 01:11 PM
