Instrument Cluster Repair
Old Jan 23, 2025 | 09:06 AM
oldguy442's Avatar
Before I attempt to solder three loose pins on my Instrument Cluster, does anyone have any advice or suggestions?
Old Jan 23, 2025 | 09:26 AM
ourkid2000's Avatar
Yes, follow these instructions. I added an extra step by extending a few lengths of solid copper wire through to the back in an X pattern and adding a drop of epoxy them to the back side just to help secure them a bit better. May not be possible with your gauge though.
https://classicoldsmobile.com/forums...repair-162067/
Old Jan 23, 2025 | 09:31 AM
F-85 4-4-2's Avatar
Send it to Redline Clock & Gauge Repair (John Dvorski). Turnaround is fast.
Welcome | Redlineg.com
Old Jan 23, 2025 | 10:43 AM
joes_olds's Avatar
Mine's in worse condition, though I am also looking at going down the soldering path. I'm also considering this replacement part
https://www.ebay.com/itm/126671212153
Old Jan 23, 2025 | 10:56 AM
oldguy442's Avatar
I saw that board on EBay. Was kind of thinking that can be my safety if I screw up the soldering.
Old Jan 23, 2025 | 11:02 AM
2blu442's Avatar
This is copied from a post dated 2009. Randy, rcorrigan5 shared what he did:
I had the same problem with my '68 442. When I removed the gauge pod, some of the pins on the printed circuit were real loose. I had heard that they can be soldered back into place but I also know that would take a person with some real skill - too much heat on that printed circuit will toast it. I noticed that, from the back side of the printed circuit, those pins are hollow. What I did was go to a model airplane store and I bought some very small (2mm), fine thread screws. They were just the right size that they would self thread and screw into the back sides of the loose pins and snug them up real nice. My gauges have worked perfectly since then. It was a somewhat tedious job, but it worked.
Old Jan 23, 2025 | 11:32 AM
oldguy442's Avatar
2blu442 that is helpful to know as well. I just removed the board from the cluster. It appears the pins are not soldered. The appear to be a press fit with 4 ears on the bottom of the board that are physically pulling the pin down into the printed circuit. I may try your way first. I see the housing is grooved to ensure the pins can't short out.
Old Jan 23, 2025 | 01:41 PM
Don’t bother with solder, use small screws instead. As someone mentioned, a good hardware store or hobby shop will have what you need.
Old Jan 29, 2025 | 12:22 PM
oldguy442's Avatar
Problem Solved
Once again you guys came through with great advice. I ordered 1.7x6 mm screws on Amazon and the problem is fixed. Thanks everyone!
Old Jan 30, 2025 | 03:29 AM
How cool! Amazing fix!
Bfg
Nov 22, 2023 04:56 AM
kbdecatur
Apr 29, 2023 12:47 AM
pclocksin
Jan 16, 2023 07:05 AM
Tom Bilse
Feb 27, 2021 11:33 AM
skydog757
Nov 19, 2016 03:58 PM
