Metal hoses?
Old December 14th, 2013 | 11:20 AM
Kotny's Avatar
Metal hoses?
Hi, I've looked at some of the engines on this site and google of what seems to look like some sort of metal hosing? Instead of the black rubber hosing. Could anyone tell me if they can understand what I've said from the poor description what they are and we're to per chase them from.Many thanks.
Old December 14th, 2013 | 11:33 AM
Are you talking about steel braded lines?
http://www.summitracing.com/search/d...eyword=Braided
Old December 14th, 2013 | 11:37 AM
Ozzie's Avatar
Is it this? http://www.summitracing.com/search/p...diator%20Hoses
Other places sell them also.
Old December 14th, 2013 | 11:43 AM
Kotny's Avatar
Yeah I think it is,have u fitted them before
Old December 15th, 2013 | 06:56 AM
Ozzie's Avatar
I have not used them, so I cannot provide personal experiences, but there are probably others who can. If you decide to use them "shop around" for the best selection and prices.
Old December 15th, 2013 | 07:54 AM
Be advised that for the most part (there are exceptions) those lines are an appearance modification only, most of them are NOT the same as the ones used on race cars and airplanes.
Old December 15th, 2013 | 08:45 AM
Octania's Avatar
Correct
if it secures the end of the hose with a std issue worm drive hose clamp, and the colorful hex shaped end fitting just basically serves to hide the hose clamp, then it is an appearance only item. REAL aviation/ race duty steel sheathed hoses terminate differently.
Old December 15th, 2013 | 08:49 PM
I used AN fitting hoses between my fuel pump and carburetor and between the transmission and transmission cooler. It is a modest investment for an excellent product. It's much easier to run AN fitting hoses than to bend steel lines. Plus, the AN fitting hoses are abrasion resistant and rated at a higher pressure than rubber hose. I highly recommend using them in your own vehicle.
hilbily
Body work
September 9th, 2014 08:54 PM
Iragh
November 17th, 2008 03:41 PM
relic
February 23rd, 2008 04:43 AM
Redog
December 29th, 2007 09:13 AM
dynamic371
March 1st, 2007 12:57 PM
Quick Reply: Metal hoses?
