Maxus Blast Cabinet
Maxus Blast Cabinet
After seeing Allan R's MAW thread in Major Builds & Projects, I think a table top sandblasting cabinet would suit all my needs. I've searched around the net and found the Maxus Blast Cabinet at Home Depot, it looks pretty good - all steel and has a 5 year limited warranty. Anyone have any experience with this type of sandblasting cabinet?
http://www.homedepot.com/buy/maxus-b...l#.UGI1zlG16H-
Last edited by red130; September 25th, 2012 at 03:53 PM. Reason: fixed the link...
red130
That cabinet is exactly the same as the one I got from Princess Auto - just a different color and marketed under a different name. Currently PA has that unit on sale for 124.99. It is also worth getting the cabinet light and 12V power supply. Otherwise it's a bugger to see in the cabinet. The light and PS run about 15.00 but are sold separately. Go figure huh?
Word to the wise: this unit does not have a filter for the media. Make a filter out of some coarse mesh (just big enough to let media but not crud through) and put it around the inlet of the media tube. That will save having to flush the gun feed with compressed air when it plugs.
Also, more importantly make sure you have a big compressor. I'm going to sell the 20 gallon one I just bought to my neighbor and I'm looking at a 60 gallon. These media blasters need sustained 125 PSI at 5-15CFM. Trust me, if you have a small compressor you will hate the sandblast cabinet, or the compressor, or both. I spent the better part of 3 hours today blasting rear backing plates. When the compressor gets below 80PSI its time to stop and let it build up, or you won't ever get anything done.
One last thing. Install a good water trap about 15 feet from the compressor to filter water that could otherwise jam your gun. A good filter is only about 20 bucks. Short air hoses are a good thing. Having a long 50 foot one on the floor just gets in the way. Short 15' hoses only cost around 9.00 each. Make sure you have enough 1/4" NPT connectors and couplers to hook everything up.
Good luck with your buying decision and sandblasting projects!
We're covered with an Ingersoll Rand air compressor, it has 150psi on tap so I'll be buying a regulator too. I'm curious what did you use for a media filter? Thanks alot for replying and all the tips. I feel alot better about buying this now.
I added one of these air dryers, and it works awesome! http://www.princessauto.com/pal/product/8055757/
Looks like this
Shane, that looks like a wall unit. I opted for a smaller in line unit for 25.00
Looks like this
Looks like this
Know what you mean. It was dry here, but the compressor in the garage is in a cool spot. So moisture forms in the lines pretty fast with all the work it's doing. I got almost half the trap filled with water today. Better to be there than in the media gun. Sometimes you just have to spend money to save yourself and equipment a headache.
The disadvantage of the bench top units is they are tiny
http://www.tptools.com/p/336,142_Bui...ed-System.html
Thanks for the tip Paul
The cabinet allyolds68 posted looks pretty good and I wouldn’t be totally against spending a little more if I were comfortable/confident in what I was buying. Have you or someone you know used TP Tools Equipment’s blast cabinets? One plus is it ships for free.
Edit: I thought this one below was the one Allyolds68 posted. That's what I get for going to kitchen and coming back to the PC.
I would be interested in something like this if I go the TP Tools route.
http://www.tptools.com/p/432,358_780...avex#aReadMore
The unit I bought is plug and play. Just add media. Unpack to use time was very quick.
I buy brand names when possible and I buy local what my budget allows. This also supports MY local community. This whole thing about not buying offshore products is exactly the same philosophy of boycotting a particular brand of gas on a particular day to make the giants hurt. It's a good theory, but doesn't work. Where do you think most of the US crude oil comes from? NOT the USA. So by the same token, you'd only buy gasoline that was refined from local bitumen? Good luck with that.
Buyers aren't stupid, but they are largely motivated by price. The conversation about where to buy and who to buy from borders close to politics IMO so I'm outta here.
My442's point is if there is a domestic source for this product, at a competitive price, then why not buy it there.
For those in the lower 48 looking for a cabinet, I recommend ANYTHING but the HF units. They are flimsy, leak like a sieve, lighting is insufficient and the hoses, gun and couplers are crap. Other than that, they are fine......
As mentioned below, no matter which model you choose, a moisture filter is a MUST. Ask me now I Know................ doh!
I bought a new 60 gal. comp from Lowes and it works HARD to keep up with me. A 2 stage would be better, but of course, more pricey.
I'm liking that Maxus Pressure Feed Blaster unit if you could hook it up to an additional compressor for added power . Not sure if that would work or not . now that I look at it , it's kinda small .
Ok, if you say so. I read it differently - with the CAPS suggesting otherwise and the directive to 'stop!'. You have a talent for interpretive soft speak Mike!
I always buy USA made first, even if the price is higher.
A couple of reasons:
1. Most chineseum products are inferior in quality, workmanship, and reliability.
2. USA made products typically have better engineering and quality
3. Buying USA made product keeps jobs here
"If it lasts twice as long, it costs half as much"
And yes, buying TP Tools stuff is a directive, as I have both a TP blast cabinet and pressure blaster.
Top shelf stuff.
Top shelf stuff.
I always buy USA made first, even if the price is higher.Like I said, I salute your efforts, patriotism and financial independence.
1. Most chineseum products are inferior in quality, workmanship, and reliability.Even though they are designed, proofed and material specified by American Engineers and companies? Unless you get a bad batch of material, which could also happen domestically, it's the cheap labor factor that makes the profit margin. If you got a bad American made product, would you be inclined to say something about American quality control?
2. USA made products typically have better engineering and quality ^^^, Although I will agree there are some companies who do build a better mousetrap. And to their efforts, I again say congratulations. And in the next breath - GM is American as apple pie. Where do you think they source out many of their parts and assembly to? That's why they want to move GM to China - for the cheap labor market.
3. Buying USA made product keeps jobs here No argument
"If it lasts twice as long, it costs half as much" Not really. When you paid twice as much as the other one not bought, it's the same.
And yes, buying TP Tools stuff is a directive, as I have both a TP blast cabinet and pressure blaster. Good for you. I have no problem with you directing yourself to buy their products.
Add another recommendation for TP tools!
I have a taiwanese cabinet that was given to me for free. After lots of frustration, clogging, broken feed hose and NO support for REPLACEMENT nozzles, I upgraded to the TP tools gun kit. Since I got the cabinet for free, it was not a big deal to spend the $90 for the new gun. But if you buy a chineseum cabinet and end up upgrading it later, you would be better off buying a TP cabinet made in USA first!
http://www.tptools.com/p/432,358_780...t-Cabinet.html
I went with the TP cabinet. I just didn't want to end up wishing I had something bigger. Also got a water separator and regulator from TP too. Hopefully it won't take too long to get here. I can't wait to try it out
Thanks to everyone who took the time to reply!
