Matching Rallye 350 engine numbers #
Old September 5th, 2011, 09:01 PM
RALLYE-DEBBIE350's Avatar
I would like to confirm matching numbers on my Rallye 350. I think I'm looking in the right place but can't find the engine number. I have been following these directions: For 1968 and up blocks, this number is located on a pad just below the cylinder head on the front left side of the engine. This number will be stamped on a machined pad on the front driver's side of the block, just below the deck surface. Typically it will be covered with a power steering bracket or something, below the number one spark plug location. I believe the power steering bracket may be holding me back. Any suggestions would be appreciated. Thanks
RALLYE-DEBBIE350 is offline
Old September 5th, 2011, 10:27 PM
hurst68olds's Avatar
Here's a sample of the numbers you're looking for.
With power steering attached, I doubt you can read the numbers.
hurst68olds is offline
Old September 6th, 2011, 01:41 PM
jpc647's Avatar
If you climb under the car and look at the ear next with an led worklight of flashlight it can be read. A little fine sandpaper may be needed to clean off some corrosion. That's why I did last weekend when I was verifying if my motor was the original(an it is, not like it matters).
jpc647 is offline
August 22nd, 2019 08:45 AM
Johnd
November 28th, 2013 08:31 AM
79MKII
August 24th, 2012 04:54 PM
BigTrav
June 1st, 2012 03:44 PM
guym
October 24th, 2007 07:42 PM
Quick Reply: Matching Rallye 350 engine numbers #
