Matching Rallye 350 engine numbers #
I would like to confirm matching numbers on my Rallye 350. I think I'm looking in the right place but can't find the engine number. I have been following these directions: For 1968 and up blocks, this number is located on a pad just below the cylinder head on the front left side of the engine. This number will be stamped on a machined pad on the front driver's side of the block, just below the deck surface. Typically it will be covered with a power steering bracket or something, below the number one spark plug location. I believe the power steering bracket may be holding me back. Any suggestions would be appreciated. Thanks
If you climb under the car and look at the ear next with an led worklight of flashlight it can be read. A little fine sandpaper may be needed to clean off some corrosion. That's why I did last weekend when I was verifying if my motor was the original(an it is, not like it matters).
August 22nd, 2019 08:45 AM
Johnd
November 28th, 2013 08:31 AM
