View Poll Results: Non Numbers Matching W30 or Numbers Matching 442
Non Numbers Matching W30 worth more
37.04%
Numbers Matching 442 worth more
62.96%
Voters: 27. You may not vote on this poll
What's worth more number matching 442 or non numbers matching w30
Old November 27th, 2013, 05:23 AM
Johnd's Avatar
Out of curiosity, which is worth more an numbers matching 442 or a non numbers matching w30 - this assuming everything else on the car is correct and in equal condition.
Also, did oldsmobile ever document how many cars were produced in any given color?
JD
Johnd is offline
Old November 27th, 2013, 10:43 AM
mister-twister's Avatar
Im not sure about the second part of your question, but is the w car a real w car? If no docs, then you have a442 with the ram air goodies wich in that case they should be damn near close in asking price.
mister-twister is offline
Old November 27th, 2013, 02:11 PM
Do you have a non numbers matching W30 or are you looking to buy something?
Allan R is offline
Old November 28th, 2013, 07:27 AM
Johnd's Avatar
I am in the market to buy something... I have looked at a couple of matching number 442's and non matching number W30's and was just curious to know which is worth more restored. All the cars are in about the same shape.
Johnd is offline
Old November 28th, 2013, 07:55 AM
oldsmobiledave's Avatar
my experience
Not enough information to answer the question. Define non matching number. Are we talking just a replacement block, or are we talking a completely replaced engine, or are we talking non original engine & trans & differential?
Also is the numbers matching 442 an OAI equipped car with all the W-30 included options like the sport mirrors & posi?
Long story short either car is worth buying. W-30 cars even with non original driveline are still W-30 cars. Go with a car that pleases you & stop worrying so much about the total resale value.
oldsmobiledave is offline
Old November 28th, 2013, 08:11 AM
Carshinebob's Avatar
I just couldn't think of a simple answer to your question. "Numbers matching" can mean different things to different poeple. There's so much more to appraising value of a restored car. Things like color, transmission, options, history, miles and quality of restoration can all have an inpact of tens of thousands of dollars. therefore "numbers matching" may not have enough impact on final appraised value to answer your question. ~BOB
Carshinebob is offline
Old November 28th, 2013, 08:19 AM
Stefano's Avatar
Hypothetically, similar car to car, generally an original drivetrain 442 will not be worth as much as a correct documented W-30 without it's original engine.
There are too many unknown factors involved in order to make an accurate assessment.
Stefano is offline
Old November 28th, 2013, 08:31 AM
jensenracing77's Avatar
X3 on not enough info. If you like originality go with the 442, It will cost MUCH less money. For a W-30, you will have to find F heads, W-455 intake, carb, distributor, red inner fenders.... This will add $$$$s of dollars to a restoration. If you don't care about originality, go with what is less money to build the way you want it. Either way, you will not likely get out of it what you put into it. I have a 70 W-30 with no original engine, trans, and no broadcast card. It is nothing more than a 442 now. I can't hardly even get 442 value out of it, let alone W-30 value.
jensenracing77 is offline
70-442-W30
July 30th, 2016 04:27 PM
SeanMiller063
September 9th, 2014 01:04 AM
Supradean
March 15th, 2014 06:21 PM
jawsmon
July 13th, 2012 07:17 AM
Al2011
August 10th, 2011 08:58 AM
Quick Reply: What's worth more number matching 442 or non numbers matching w30
