master cylinder bleeding
Old Aug 25, 2021 | 08:06 PM
gmg's Avatar
gmg
I think I have air bubbles in my 1962 F85 master cylinder (original to car). I don't see any bleeding ports on it, just one line coming out that splits into the wheel lines. Can I bleed the master cylinder on the car (instead of bench bleeding)? Will the master cylinder bleed out by bleeding the brakes one at a time? Thanks for any help.
Old Aug 25, 2021 | 08:46 PM
truckman5000's Avatar
W30
Get a tool.
Or crack each wheel, let it drip,, leave a bucket under..
keep filing cylinder
Repeat x3
Old Aug 25, 2021 | 09:49 PM
You can get a bench bleed kit from amazon and route it back into itself, pump until no more bubbles, then hook the line back up and bleed brakes normally, keeping reservoir full until no bubbles at all 4 wheels. You'll want a helper or a vacuum pump.
Old Aug 26, 2021 | 04:16 AM
Sugar Bear's Avatar
Use a new section of brake line from an auto parts store to loop the master fluid output back into the reservoir. When done bleeding the master bleed the wheels.
Be careful using a master that old, the internal seals may be in need of replacement leading to brake failure. That is probably a single master, not converted to a tandem correct?
Good luck!!!
ilandtime
Brakes/Hydraulic Systems
Mar 10, 2014 09:25 PM
kds 69 442
Oct 23, 2013 02:40 PM
al714
15
Sep 20, 2013 08:06 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
texasred
May 1, 2012 08:48 PM
