Lighter not strong enough?
Old May 10, 2017 | 08:54 PM
unfoldthesoul's Avatar
I installed a lighter socket in my car for use in charging my phone. I'm finding that it's 'showing' that it's charging, but the phone power gradually weakens over time. First, I thought it was my charging unit, but I used the socket charger from my truck which I know is great, and the issue continues. Wondering if anyone has had similar experience.
I may not be using the right terminology but, could it be that the wiring for the lighter isn't sufficient for today's phones? If this is the case, can anyone recommend a solution?
Thanks!
Ken
Old May 10, 2017 | 09:27 PM
Where did you install it? The GM fusebox for your car should have a 20 amp circuit powering most everything in the dash. Should say something like CLK LTR CTSY for clock, lighter, and courtesy.
A 20 amp circuit will definitely give The Juice to a charger, which would only max pull 2 amps. Now, that's factory wiring, and it was designed to take most of that 20 amps (which is like a hairdryer going ***** out) and feed it to the lighter, which was basically a giant resistor that heated up. The lighter probably pulled at least 5x whatever you phone could ever do.
The problem is, where did you wire yours, and what sort of wiring did you use? What sort of socket? Does it have its own resistor in it to pull the amps down?
Old May 11, 2017 | 02:39 AM
midnightleadfoot's Avatar
ph_ckstick1
Why not just add a ubs outlet they make them to fit the lighter oem holes.
Old May 11, 2017 | 03:54 AM
I've found that some sockets and chargers are not compatible with each other. The prongs don't line up properly.
Old May 11, 2017 | 07:35 AM
AJFink's Avatar
Where do you find these?
Old May 11, 2017 | 07:48 AM
Amazon carries them
Amazon Amazon
Walmart
https://www.walmart.com/ip/SODIAL-12...tlet/183726347
Old May 11, 2017 | 08:06 AM
ph_ckstick1
Almost every repop vender, amazon, ebay, your local auto audio store.. best buy, I almost listed radio shack opps..
Old May 11, 2017 | 08:55 AM
Still have a Radio Shack here in Mayberry.
Old May 11, 2017 | 08:56 AM
Ah yes, the dearly departed shack.
Old May 11, 2017 | 01:13 PM
rjohnson442's Avatar
Mr. Johnson
I just got one on amazon like that for 15 bucks that has a volt gauge between the sockets. you can read it with the lid on to. If you have an Iphone or a samsung some of those suckers can draw up to 5 amps charging. as for why it's draining your phone instead of charging I'd just run dedicated wires from the fuse panes to the plug and leave the original wires be. This is one of those you may create more problems before you fix the original one.
Old May 13, 2017 | 08:18 PM
Junkman's Avatar
My wife had the same problem with her phone, plugged into the socket in the car. Turned out that the phone battery was going bad. Put a new battery into the phone, and no more problems.
allyolds68
Feb 9, 2013 08:01 PM
Redog
Aug 17, 2012 02:34 PM
85cutlass6.6
Aug 25, 2011 09:14 AM
Steeb
Feb 19, 2009 11:15 PM
esisson
Nov 19, 2008 10:40 AM
