Jet-Hot questions
Old Aug 19, 2011 | 03:11 PM
WTony's Avatar
Jet-Hot questions
Im looking for info on where to get a pair of exhaust manifolds jet hot coated.
Has anyone else done this, and how does it hold up? Im told that after its coated, it has to be cured by baking from 100-800* cycle's several times or it wont stick. Anyone know about how its done or how well it works out?
Old Aug 19, 2011 | 04:27 PM
My442's Avatar
Exclamation
I used HPC to coat a set of W and Z manifolds, and an aluminum O4B intake.
The parts have been on the car for about 9 years, and have dyno time too.
They look EXACTLY like the day I put them on.
There is no paint that will match the durability.
Old Aug 19, 2011 | 05:13 PM
TripDeuces's Avatar
I just saw a set of Jet-Hot coated headers at a local car show. They were seven years old and looked fairly new. I've enclosed a pic of them.
Old Aug 19, 2011 | 05:15 PM
WTony's Avatar
What is HPC?
Any leads on a good place for Jet Hot? And will they do cast?
Old Aug 19, 2011 | 05:22 PM
TripDeuces's Avatar
http://jet-hot.com/
NC, OK and AZ are the three locations
Old Aug 19, 2011 | 06:03 PM
Tucsonbob's Avatar
I had mine done in Phoenix.
Old Aug 19, 2011 | 07:18 PM
WTony's Avatar
Originally Posted by TripDeuces
http://jet-hot.com/
Thanks George!
Old Aug 19, 2011 | 08:11 PM
TripDeuces's Avatar
Tony did you get the engine together yet? Would like to hear how it all went.
Old Aug 19, 2011 | 08:40 PM
firefrost gold's Avatar
I have heard you dont want to break in your cam with new coated headers
I did on my pontiac and they Look ok but not holding up as will as I would like them too. They were from ram air restorations . They are in mich so who knowsif they do their own or what .
Old Aug 19, 2011 | 10:04 PM
DeltaPace77's Avatar
I have Jet-Hotted long tubes on my 455, and still look like the day I put them on. Bought them new from Summit Racing that way, and they basically sent them to Jet-Hot, and Jet-Hot sent them to me. Actually have a Jet-Hot catalog, and yes they'll do cast iron exhaust manifolds, aluminum intakes, ext. Good stuff, as actually a bit soft, and takes some banging around. They do warn of a proper carb air/fuel ratio, as if running to lean(overly hot), could damage it. Never had any problems with mine.
Old Aug 20, 2011 | 06:39 AM
Redog's Avatar
There's also one in here about an hour outside of Philly.
Personally, I wouldn't use them. Yes they shine and stuff, but I've heard nothing but bad things about them and their coatings dont last.
I perfer powder coating. I'm a good customer at a place in Warminster, PA (about 20 minutes from Philly) www.boneheadperformance.com and my Alero manifold is on their website.
under "Automotive coating" photo gallery, first pic in the 4th row
http://boneheadperformance.com/photo...m=5&gallery=90
Old Aug 20, 2011 | 07:04 AM
dc2x4drvr's Avatar
I had HPC coat my W Z's years ago, and they looked perfect when I took them off. Apparently HPC is now Jet-Hot.
Old Aug 20, 2011 | 10:23 AM
WTony's Avatar
Warminster is a little over an hour from me. I deal with another buisness in the same town. Their website says $160 for ceramic coating on a pair of V8 exhaust manifolds. Doesnt sound to bad to me, especially if I can bring them there and pick them up.
Old Aug 20, 2011 | 11:23 AM
As mentioned Ive had good luck with Jet-Hot. I did't realize there is a powder coating material avialible to withstand the heat of exhaust systems. Another place mentioned by a guy on the Corvette forum is Swain Tech Coatings. If you check out their web site they show coating the combustion chambers of cyliner heads and piston tops.
Old Aug 20, 2011 | 11:36 AM
Redog's Avatar
If you do, let me know and I'll tell them to expect you
They sponser our Alero show every year in Michigan, so I try to retunr the favor as much as possible
Old Aug 20, 2011 | 04:04 PM
380 Racer's Avatar
Nothing but good things to say about Jet Hot. The Kooks I have on my car were done 6 yrs ago and still look great.
Old Aug 20, 2011 | 05:23 PM
stevengerard's Avatar
I just did some research, looks like ceramic coating come in a powder coating as well, so if you have access to a powder coating system you can do it yourself.
Old Aug 20, 2011 | 07:49 PM
nonhog's Avatar
Registered car nut
I had a local shop ceramic coat some SBC manifolds a few years back.
Was very happy, One bit of warning if you do any grinding be sure to smooth them as all deep sanding marks still showed.
Not sure I'll ever smooth cast iron again. What a pain.
Skitch72
Oct 27, 2013 09:00 AM
spate51
Mar 10, 2012 09:32 AM
oldzy
Aug 29, 2010 09:18 PM
DAN76
Jul 24, 2009 09:01 AM
Oldsproject
Jun 21, 2008 07:03 AM
