J head replacements
Old August 16th, 2018, 02:31 PM
Raffi's Avatar
J head replacements
Hi,
I have a 1968 442 with a 455 engine. Unfortunately, the head is cracked at the exhaust port. Its an iron cast with J heads (411783) on a 396021F block. (I apologise if this seems redundant but I'm from the U.K and know very little about engines.) What would you recommend as a replacement? I have been recommended the Elderbrock Performer RPM 60519. Is this right?
Thank you in advance
Raffi is offline
Old August 16th, 2018, 02:50 PM
svnt442's Avatar
Unless you want a ton of expense, stick with factory castings. I would try and find G or GA heads as those are much better castings then the J heads and are setup from the factory to run unleaded fuel.
svnt442 is offline
Old August 16th, 2018, 02:51 PM
Raffi's Avatar
Thank you.
is there a good site for factory castings?
Raffi is offline
Old August 16th, 2018, 03:07 PM
svnt442's Avatar
I'm sure someone here has something.
svnt442 is offline
Old August 16th, 2018, 03:40 PM
svnt442's Avatar
I just found this
https://inlandempire.craigslist.org/...645382775.html
svnt442 is offline
Old August 16th, 2018, 06:00 PM
I realize that shipping heavy parts like this to the UK (which part are you located in?) can be pricey. Check this link - Bob Kelso Retirement sale
He has a set of 1971 G heads in his post for $100. They are cores
If you want to buy locally in the UK, do your parts stores have to order the parts in from off shore?
Allan R is offline
Old August 16th, 2018, 09:08 PM
svnt442's Avatar
He has a set of 1971 F heads in his post for $100. They are cores
If they are F heads they would be 1970 and not set up for unleaded fuel.
svnt442 is offline
Old August 17th, 2018, 12:52 AM
Raffi's Avatar
Thank you so much for your help.
Should I stay away from the Elderbrock Performer RPM 60519 -the guys at Summit said it would work?
Raffi is offline
Old August 17th, 2018, 06:19 AM
Randy, a typo on my part. They are G heads. Fixed it in the post.
Allan R is offline
Old August 17th, 2018, 07:39 AM
ronskal's Avatar
The Edelbrock 60519's are excellent- just pricey. Get them if it fits your budget. They will be far superior to the J heads coming off.
ronskal is offline
Old August 17th, 2018, 08:21 AM
Have you taken the J heads to a welder to see if they can be repaired? This might be a cheaper option. I know cast iron is difficult to weld, but...
Olds64 is online now
Old August 17th, 2018, 10:25 AM
Of course they will work, and they're aluminum which isn't as heavy as cast iron. Better machined too.
What's your budget? At almost $US1150 just for the heads, not counting import tax and shipping I think you'd be far better going with a stock head and having it rebuilt as needed unless you're planning to race the car, then you'll likely want to change the cam, pistons, and rockers. The 68 you have obviously doesn't have the original engine so whatever changes you do the the 455 won't matter too much. It all comes down to how much $$$ you have to spend and the time to do it.
Just my opinion but 990 € is steep for those heads. Then again, it may be ok for you if you're just looking for something to bolt on already built.
Allan R is offline
Old August 17th, 2018, 10:59 AM
Raffi's Avatar
Is there anything else I should consider when replacing the old j heads with the Edelbrocks? Pushrods, etc?
Raffi is offline
Old August 17th, 2018, 11:00 AM
Raffi's Avatar
I'm told they can't welded. Its in the exhaust port.
Raffi is offline
Old August 17th, 2018, 11:06 AM
Raffi's Avatar
Hi Allan,
Thanks for your response. I'm struggling to find stock heads here and the old one can't be rebuilt.
It seems I have to choose between the Edelbrock RPM 60519 or this one (see pic) - I don't what else I need though.
Raffi is offline
Old August 17th, 2018, 12:05 PM
Raffi, did you check that link I posted to the G heads Bob Kelso has? For $100 and a rebuild you'd be ahead of the game. You can likely have them rebuilt in the US and shipped to you in the UK or have them rebuilt when you get them. You wouldn't have to change anything.
Allan R is offline
Old August 17th, 2018, 12:18 PM
Raffi's Avatar
Hi Allan,
I have messaged him to see if they are still available.
When you say rebuilt - does that mean adapted to fit what I have? Again, apologies for my ignorance.
Raffi is offline
Old August 17th, 2018, 12:53 PM
Boiler_81's Avatar
Adapting is not required, Olds big block heads all interchange. What is meant by rebuilt is the valves and valve seats ground and valve guides checked and replaced if necessary. This is pretty standard stuff for any automotive machine shop to perform. Personally, I would go with a good set of iron heads rather than spend the money on the aluminums unless you are looking for a high performance rebuild of your current engine.
Hi Allan,
Boiler_81 is offline
Old August 17th, 2018, 01:10 PM
^^^What Boiler said. The G heads are simply from 1971 production. They have induction hardened exhaust ports. The J heads have induction hardened intake and exhaust ports. If the G heads are in really decent core condition it shouldn't cost all that much to have them rebuilt. When the machine shop is doing the rebuild they should magnflux the head to make sure there aren't any cracks. If they are good cores the decks shouldn't need machining, just a clean up. Pretty standard stuff at a good shop. They will install new valves (faster than cleaning old ones) and lap them, keepers, springs (if needed), and valve seals.
Allan R is offline
Old August 17th, 2018, 05:24 PM
svnt442's Avatar
The Edelbrock heads are not a bolt on and go proposition. You would need to get new pushrods (after measuring for them), rocker arms and guide plates. Then you would have an adjustable valve train where the stock heads do not. That is not a bad thing, but it adds to the complexity of the system. If you want bolt on and go then just stick with the factory iron heads. The G heads will work as a direct swap and there is nothing special that will need to be done to make them work.
svnt442 is offline
Old August 17th, 2018, 06:12 PM
Unless you can find some ready to go cheap iron heads, I’d go aftermarket every time. Consider the cost to PROPERLY rebuild iron heads, springs, valve guides, valves,exhaust seats, milling, etc it’s not hard to get close to the price of aftermarket. Then consider the added 50-60hp (probably closer to 75 when replacing junk J heads!) it’s a no brainer. The cost to add 50 hp with no trade off in drivability is hard to do for 1000 bucks. Just my opinion
matt69olds is online now
Old August 17th, 2018, 07:13 PM
71 & 72,now I want a 68
w-30dreamin's Avatar
That price is per head not for a set of heads.
w-30dreamin is offline
Old August 18th, 2018, 07:32 AM
Whuuuut?? :eek" Are you sure? Their description says 'heads' not 'per head'.
Allan R is offline
Old August 18th, 2018, 07:58 AM
Bernard Mondello's Avatar
Price of Edelbrock cylinder heads?
Yes the price of Edelbrock Oldsmobile cylinder heads are $1136.50 ea or $2273.00 a pair...
We sell many sets a month of these and our SpeedMaster cylinder heads!
Bernard Mondello Racing Enterprises
Corona ,California. 951-371-1432
Bernard Mondello is offline
Old August 18th, 2018, 10:06 AM
Well after reading that, the cost of those G heads and a valve job look really effective and cost efficient.
Allan R is offline
Old August 18th, 2018, 03:24 PM
Raffi's Avatar
Hi,
I have asked Bob about the G Heads and we're looking into shipping. Should I totally discount the other heads I posted - the non brand heads? Apparently, they are cast from virgin A356 and are heat treated to T6 specs??
Raffi is offline
Old August 18th, 2018, 03:27 PM
Your call on the others, but they are incredibly expensive,and as noted by others, they are not direct bolt on, whereas the G heads are. Even if the G heads cost a lot to ship, they're going to be easier to replace on your engine and much less expensive overall.
Allan R is offline
Old August 18th, 2018, 07:00 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Hi,
Bernard Mondello, uses the same heads as Olds Rocket Parts, except he uses quality parts, proper machining and assembly. Buying out of box assembled Speedmaster/Procomp heads is a crap shoot, there is a reason they cost less. Benard's ready to go Procomp heads are still much cheaper than Performer RPM heads.
olds 307 and 403 is offline
73aussie455
August 9th, 2019 04:40 PM
cus
May 19th, 2016 04:03 PM
alex.1979
July 5th, 2015 07:10 PM
bert442
April 24th, 2015 04:36 PM
The_Jeremiah
September 26th, 2007 04:29 PM
Quick Reply: J head replacements
