Installing Exhaust Manilifold
Old January 31st, 2019, 08:05 AM
hurst1's Avatar
Good day everyone.
We are installing our New RH Side Exhaust Manilfold this weekend. I read someplace that they originally we not installed with gaskets. Do we need to use a gasket, sealant or just attach it and tighten it up. Its a 73 Oldsmobile Omega.
Thanks Bill
hurst1 is offline
Old January 31st, 2019, 08:37 AM
rand5204's Avatar
Use a gasket. It will helps insure against leaks fro any small defects in the mating surfaces.
rand5204 is offline
Old January 31st, 2019, 09:17 AM
The factory did not use gaskets. If the manifold and head are not pitted, just install them per the factory manual. Using a gasket, especially the composition ones you get in engine gasket sets, can cause moisture to be retained and actually increase rust and pitting at the mating surfaces (as happened on my 67). If you MUST use gaskets, spend the money and use Remflex graphite-loaded gaskets. These are the best I've ever used. I had to use them on my 67 due to the pitting. Normally I don't use any with stock manifolds.
joe_padavano is offline
Old February 1st, 2019, 10:09 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Check the manifold for trueness new or used. You can get a small amount of warp out with various home methods. Otherwise, mill it.
Use copper anti-seize on all exhaust fasteners. It will go together and come apart easier.
Recheck fastener torque after several heat cycles. Not sure if its a wet or dry torque? Careful to not over torque.
(Rule of thumb, back off 10% on dry torque values when using lube or anti-seize).
droldsmorland is offline
Old February 1st, 2019, 10:15 AM
jcdynamic88's Avatar
i would also recommend using new bolts ,seems to me the old worn threads have a tendency to loosen up.
jcdynamic88 is offline
Old February 14th, 2019, 07:49 PM
hurst1's Avatar
Thanks everyone for the information that you provided. We installed it with a gasket and the only issue was lining up the exhaust downturn with the manifold bolts. All in all very easy.
hurst1 is offline
kiloman_11
June 26th, 2019 06:10 PM
Bfg
September 15th, 2016 05:35 AM
ChrisM
March 19th, 2015 08:57 AM
Big red72
January 29th, 2013 07:53 AM
sixty9olds
June 20th, 2012 09:37 AM
Quick Reply: Installing Exhaust Manilifold
