Ignition switch
Welcome to the site. The key is required to do this without destroying the locking barrel. If you are replacing the switch, you might be able to jam a screwdriver in there and manhandle the switch to turn to the accy side. Then stick a paper clip in the little hole in the front of the switch and twist the tumbler farther to the left until the tumbler slides out the front. Then unscrew the lock nut and slide the switch out the back.
If your not replacing the switch then you need the key code off another lock that uses the same key. Then you can get a new key made that fits.
mm89olds
April 6th, 2006 11:03 AM
