ignition lock cylinder
Easiest way to remove without no damage.
Reason for removing key stuck in ignition won't go foward nor will it go back it's basically stuck on acc need help plz.
I assume this is a car with the lock cylinder on the column? Are you sure the problem isn't simply that the steering wheel is turned and the lock pin is binding? Have you tried jacking the front wheels off the ground to release pressure on the linkage? How about the shift linkage from the column to the trans? Try temporarily disconnecting it at the firewall then push all the way up on the arm that comes out of the base of the column. Rarely does the lock cylinder itself go bad.
If you DO want to pull the lock cylinder, here are the instructions.
That website covers more that just lock cylinder removal, so stop there.
OK, if it isn't binding linkage then the only other things to check is the rod from the ignition switch to the lock cylinder and the rack that the cylinder drives. Sometimes the rack or drive gear break.
johnnyhawthorn
February 12th, 2014 11:47 AM
