How much for a disc brake setup?
What would you expect to pay for a 1970 disc brake setup from a junkyard? Spindles, backing plate, caliper brackets, calipers, metering block/proportioning valve, steel lines and their brackets.
thanks
Tom
thanks
Tom
I bet the used set up is around 200.00 and if you take your time you can have a nice new set up with some upgrades for around 600.00 keep in mind on the used set up parts might not be good and need replaced
Also you will have to change out brake lines depending on you it can range from 20.00-100.00 to make or buy prebent lines
Mocephus
October 1st, 2021 09:45 AM
