How much for a disc brake setup?
Old Jul 29, 2013 | 05:07 AM
Tom442's Avatar
What would you expect to pay for a 1970 disc brake setup from a junkyard? Spindles, backing plate, caliper brackets, calipers, metering block/proportioning valve, steel lines and their brackets.
thanks
Tom
Old Jul 29, 2013 | 05:51 AM
Kennybill's Avatar
I wouldn't waste time/money on used setup. New setups with options such as dropped spindles are reasonably priced. Jmo, Ken
Old Jul 29, 2013 | 06:09 AM
oldstata's Avatar
Justin
I bet the used set up is around 200.00 and if you take your time you can have a nice new set up with some upgrades for around 600.00 keep in mind on the used set up parts might not be good and need replaced
Also you will have to change out brake lines depending on you it can range from 20.00-100.00 to make or buy prebent lines
Old Jul 29, 2013 | 06:16 AM
oldspackrat's Avatar
We sell complete used set ups for between $200.00-$275.00.
Mocephus
Oct 1, 2021 09:45 AM
Wilson05
Brakes/Hydraulic Systems
Dec 11, 2009 02:33 AM
cardinals25
Mar 24, 2009 06:39 AM
OldsMotion
Jul 12, 2007 12:45 PM
