Help Identifying Part
Old Sep 15, 2023 | 05:53 AM
Tom Canfield's Avatar
Hello everyone,
I am working on tearing down a 455 (1968 I believe) for parts / rebuild and I found this part that I cannot seem to identify or find any information on. It was mounted on the intake, just in front of the throttle linkage on the carburetor (2 barrel). The throttle are would rest on this "button" when at idle it seams. The button can move in and out of the disc section, which seems to contain a diaphragm. But there are no connections, electrical or vacuum to this piece.
Thanks for any help in advance!
Old Sep 15, 2023 | 05:58 AM
Used on the slow idle side of the circuit referred to as the dashpot. Should be readily available at your normal automotive parts supply stores.
Dashpot adjustment 72 olds 350 bbl
Old Sep 15, 2023 | 06:04 AM
Here's another link; but I think you have enough information to perform additional research. If you own the CSM you should see images of the dashpot and a small section on how to adjust it.
1968 Olds 98 carb dash pot
Old Sep 15, 2023 | 06:19 AM
Case closed! Thanks for the info Chief!
Old Sep 15, 2023 | 06:44 AM
Sure thing.
Old Sep 15, 2023 | 07:25 AM
zl1 camaro's Avatar
I believe this part is called a anti dieseling valve. it dropped the idle down to prevent the engine from running on after turning the key off. However they usually have a electric connector or vacuum port ?
Old Sep 15, 2023 | 07:42 AM
Originally Posted by zl1 camaro
I believe this part is called a anti dieseling valve. it dropped the idle to down to prevent the engine from running on after turning the key off. However they usually have a electric connector or vacuum port ?
Nope. It is not electric. It is called a dashpot and all it does is dampen the throttle closing if you lift off the gas quickly to ensure the engine doesn't stall.
Old Sep 15, 2023 | 07:47 AM
zl1 camaro's Avatar
That explains why there is no vacuum or electric source. You be the man...
jpayne_80@hotmail.com
Apr 1, 2020 06:35 PM
Trashylowrider
Apr 16, 2019 04:59 AM
442fanatic
Jan 15, 2016 09:42 AM
Kanesdaddy
Jul 8, 2014 11:04 AM
dallasite21
Sep 24, 2009 03:38 AM
