Help Identifying Dash Screws
Old June 22nd, 2018, 01:34 PM
adrianirish's Avatar
I am looking to do some work to my dash and want to remove the pad.... however there are screws I've never seen before. Does anyone know what these are called? Any help is greatly appreciated!
adrianirish is offline
Old June 22nd, 2018, 01:45 PM
m371961's Avatar
I believe that is a clutch head drive. There are 3 sizes.
m371961 is offline
Old June 22nd, 2018, 02:22 PM
Heres a set at amazon. I think Lowes and Home Depot sell them also.
Amazon Amazon
oldcutlass is online now
Old June 22nd, 2018, 07:22 PM
cjsdad's Avatar
Harbor Freight sells a screwdriver bit combo for about 10 dollars that includes clutch drive. They fit standard magnetic screwdrivers. It includes Hex, Torx, Security Hex and Torx, Phillips, Flat, Clutch, Spline, Square, Posi-Drive (which incidentally fits most GM sill-plate screwheads) and a few other bit types. Well worth the investment because you will run into most of those on cars eventually. As long as you don't go all Magilla Gorilla with them they will last for the home hobbyist.
https://www.harborfreight.com/100-Pc...ase-68457.html
cjsdad is offline
Old June 22nd, 2018, 07:31 PM
cherokeepeople's Avatar
yup clutch bit.sometimes you can use a phillips screwdriver on em if the screws not too tight
cherokeepeople is offline
olwreckman
October 26th, 2015 12:55 PM
Danny Boy
July 19th, 2015 03:44 AM
bummerino
October 25th, 2011 08:28 AM
bummerino
April 27th, 2010 08:55 PM
mugzilla
September 7th, 2009 05:57 PM
Quick Reply: Help Identifying Dash Screws
