HEI distributor for a 303
Old May 26, 2019 | 05:45 AM
1stGrumpy's Avatar
I ran across this on Ebay the other day, they claim that they have one for the 303. Anybody have any knowledge and/or information on these? Thanks...
https://www.ebay.com/itm/TSP-HEI-Dis...53.m1438.l2649
Old May 26, 2019 | 06:54 AM
Tedd Thompson's Avatar
Morning, I can't find anywhere on that ad that states it is for a first generation engine (303). I don't think that one will work. If you need a pointless ignition you can get a Pertronix setup that uses your old distributor and cap and new guts but other than not having to set your points ever 8 to 10 thousand miles there is no performance gain. Just remember pointless ignition come with there own problems.... Lost in the fifties....Tedd
Old May 26, 2019 | 07:01 AM
don71's Avatar
same but different
I no nothing about that unit fitting the 303. Contact them and make for sure.
How ever I do know that some companies can put together working and fitting HEI style distributors for engines that never used them. Example an AMC 258. Its nothing more than a chevy 250 unit with the proper amc gear on it. Its a common swap in the jeep world.
Old May 26, 2019 | 07:15 AM
1stGrumpy's Avatar
Morning, I can't find anywhere on that ad that states it is for a first generation engine (303). I don't think that one will work. If you need a pointless ignition you can get a Pertronic setup that uses your old distributor and cap and new guts but other than not having to set your points ever 8 to 10 thousand miles there is no performance gain. Just remember pointless ignition come with there own problems.... Lost in the fifties....Tedd
Good morning to you as well, Tedd. I contacted the company and they told me that they had a listing in their catalog for the 303. I also found the listing on their website. I have the 6 volt Pertronix already installed but I am thinking about converting over to 12 volt and would prefer an HEI style over another Pertronix unit. Besides, this is close to half the cost!
As I mentioned to Tedd, I have contacted them and they said that they have one for 303. I was just hoping to find some information from someone other than the seller, someone that has actually installed one in their 303 would even be better.
Old May 26, 2019 | 08:07 AM
redoldsman's Avatar
Proud Viet Nam Veteran
One word of caution if they do have that distributor is to be sure you have room to install it. The GM HEI is much larger diameter than the old points distributor so you will need firewall clearance. I know on Tri5 Chevies you can't use the HEI because of this. Do they give a cost for the HEI?
Old May 26, 2019 | 09:18 AM
1stGrumpy's Avatar
Yes, they show it at $57.19 ea. and that's another thing that concerns me. Clearance was another issue that I had concerns about, another reason why I had hoped that someone would chime in that had bought one but I can always get the dimensions and measure it myself.
Old May 26, 2019 | 09:27 AM
Be wary of bargain HEI units, especially for the early 1st generation Olds motors. I installed a Summit HEI in my 71 98 and it has been nothing but problems. I should have gone with a Pertronix kit.
Old May 26, 2019 | 12:27 PM
The Summit HEI is a Chinese made unit, and what I have read is it's a gamble as to whether they will work properly or not. You can find real GM HEI distributors for cheap. I bought two for $35 each.
Old May 26, 2019 | 03:27 PM
That unit will not work on a 303, its for the next generation of V8's. No one makes one for your engine, there is no real calling for it. You may be able to convert or have yours converted to a small cap HEI through companies that specialize in that sort of thing. Most in your model series engine keep the points or go with a points replacement.
Old May 26, 2019 | 08:12 PM
I'm wondering if they are looking at a 330 and not a 303. I've never seen a hei for a first generation Old's but I learn something most every day on this site..... Tedd
Old May 27, 2019 | 04:54 AM
1stGrumpy's Avatar
Cool
https://www.carid.com/tsp/tsp-hei-di...839352545.html
See number 11 in "Engine Type Specific"
Old May 27, 2019 | 05:13 AM
I have yet to see a one, but hey if its on the internet it must be true.
Old May 27, 2019 | 05:43 AM
1stGrumpy's Avatar
Yeah, that's what I was thinking!
Old May 27, 2019 | 08:17 AM
Looks to me that they have included all the first generation engines never seen one ever on a car. My concern would be if it did not clear the air cleaner or hit the windshield wiper motor. Like I said I learn something everyday on this site.
Something else you might try is use your existing 6 volt distributor with 12 volts and add a ballast resistor to knock it down to 8 volts or so. May run for ever or may not. You might call Pertronix and see if 8 volts would smoke the module.... Tedd
Old Jun 2, 2019 | 05:18 AM
1stGrumpy's Avatar
I talked with Pertronix on Friday, they told me that my 6 volt unit would handle 8 volts without any problems.
I don't think that I want to be the first person to try out their HEI distributor, I was hoping that someone on here might have had some experience with it.
Old Jun 2, 2019 | 06:56 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
IMO keep the points. Rebuild it if needed...bushings mech advance etc. Install a high qual point cond and run it.
Old Jun 4, 2019 | 12:36 PM
67OAI's Avatar
Old(s)GuysRule
Look into "davessmallbodyheis.com" for a possible solution. I don't have personal experience with him as of now but have seen good reviews on this and other forums.
Chuck Cole
Sep 23, 2018 02:32 PM
Oldracerjones
Mar 1, 2016 08:50 AM
jo75olds
Aug 18, 2011 07:07 AM
Thomas Simcich
Jul 23, 2010 12:53 PM
DAN76
Aug 9, 2009 01:04 PM
