Heater hose / where too?
I have a 455 with a performer intake. Looking at my assembly drawings the heater hose goes to the passenger side the intake. The problem is the fitting is very close to the coil . I would like to route it correctly as it requires less hose and less clutter over the motor. Any sugestions on where to move the coil too?
Tim72
Tim72
The clearence should be fine. The performer manifold has the same water port layouts as the stock manifold. Are you sure the coil is mounted correctly. You could mount the coil on the firewall if it still doesn't work for you.
EightballZ
August 24th, 2015 04:56 AM
bob p
Brakes/Hydraulic Systems
23
August 16th, 2015 06:30 AM
RAMBOW
October 15th, 2011 05:54 AM
agtw31
July 20th, 2009 09:58 AM
