Ground Strap / Firewall components
I am getting ready to populate the engine compartment firewall.
I am sure I will have other questions on this subject but to start.
1. Does the paint need to be removed where the ground strap from the engine block attaches to the firewall or does the start washer pierce the paint sufficiently to get proper ground?
I'll embellish a moment. Think of your entire car as one large piece of metal - the largest single piece of metal is the engine block - this is where you will find the greatest density of electrons (comprised in the metal engine block). There exists many pieces of metal in the vehicle & each component which requires a power source requires a ground. Electrons don't (in reality) "flow", they're contained in every piece of metal. However, by convention we refer to electron "flow" as it relates to an electrical "circuit". We say electrons (negatively charged) flow from the battery anode (-) negative terminal to the battery cathode (+) positive terminal - this then completes the electrical circuit. Any impedance of electron "flow" can/will disrupt the ground source of an electrical circuit. Always best to use as much solid metal as is possible when establishing a ground source.
You can also use Fluid Film instead of paint if you burnish the paint off of either end of the ground straps.
https://www.theruststore.com/Fluid-Film-C67.aspx
Ended up removing the paint and using a dab of dielectric grease to prevent corrosion.
I would think the star washer would make sense to contact the firewall and pierce the paint.
Since I ground the paint off I opted to put a star washer on the outside of the ground connector thinking the flat of the ground strap would make a better connection.
Thoughts?
Thoughts?
I'm not sure what the OE configuration is.
That being said, the best workman like practice is to put the washer between the body and the ground strap vs. between the bolt and the ground strap. All ground strap contact points should be burnished and free of paint.
Thoughts?
Thoughts?
I agree, the star washer seems redundant to the point of un-neccesary the way you put the ring connector next to the firewall. Norm, sounds like you were describing what I was taught as "hole theory" about electron "flow". Is that correct?
Dan - Short answer - Yes. Hole theory is an analogy, but it's a very good working analogy to the electron flow of an (externally) induced electrical circuit, such as a battery.
Hole flow is a good analogy, esp. since this most likely isn't the audience to discuss the fundamentals of basic chemical bonds and the applicable scientific equations which define atoms and their electric potential energy. It's a good working analogy for defining electron flow when there is an external electrical current being supplied such as a battery. Voo Doo magic.
