Going back to a Quadrajet, what am I missing?
I'm getting rid of this intake and carb and going back to a stock intake or an Edelbrock 04B with a Quadrajet. I know I need a throttle bracket, springs, choke tubes, fuel line and bolts, not only for the carb,
but intake as well. Anything else you guys see that I might need? I'm going to post in Parts Wanted and want to be sure to get everything.
I prefer a stock/stockish look. I would prefer a W30 intake but funds aren't readily available for that now. Also I have an OAI hood and the OAI air cleaner doesn't work with the height of the Performer. And the Performer is a square bore and I want to lose the Demon for a spread bore Quadrajet.
OK, that makes sense.
But you say your Performer has a square bore flange? That is different than my Performer 455 which has a spreadbore carb flange. I guess actually it has dual mounting holes, for both square and spreadbore carbs. But yeah, maybe a bit too tall for the OAI setup.
