Gasket set
Old Dec 19, 2021 | 04:53 PM
Mr.Smooth's Avatar
Gasket set
Im looking to replace all the gaskets on my 68 400. Ive heard dont use cheap and dont use cork. I will be replacing everything except the head gaskets. Ive seen sets from $40-280.
Does anyone have a part number for a good gasket set?
Old Dec 19, 2021 | 06:42 PM
don71's Avatar
same but different
I've used felpro for years. The CS8171-2 should cover most of it.
VS50259rfor the valve cover gasket, at least they say it's rubber, not cork.
Old Dec 20, 2021 | 03:08 AM
fleming442's Avatar
You can try to find a gasket set for a diesel to get rubber, but I don't think they make them anymore. Rocket Racing has rubber valve cover gaskets. You can use a neoprene BBF instead of the rope rear main.
Old Dec 20, 2021 | 04:30 AM
BillK's Avatar
To be honest with you I have better luck with cork for the valve covers on some engines. The rubber replacements are usually too thin and wont compress to match the usually mangled valve covers. No matter how hard you try it is almost impossible to get the valve covers as straight as they were when new.
Otherwise I always use Fel Pro.
Old Dec 20, 2021 | 07:32 AM
I also recommend the rubber valve cover gasket. Note that there are two versions, so ensure you get the thick ones recommended above
FEL-PRO VS50259R are 11/64" thick
FEL-PRO VS13403R are 3/32" thick
Old Dec 20, 2021 | 10:13 AM
As long as it’s a decent gasket, proper surface prep and installation is more important than the brand.
jb77
May 12, 2021 12:56 PM
Oldssupreme
Jul 27, 2016 03:56 AM
jensenracing77
Jul 30, 2012 11:13 PM
coppercutlass
Oct 25, 2011 04:38 PM
Joel
Mar 7, 2011 10:45 AM
