G head disassembly.
G head disassembly.
I am breaking down some old G's I have for another build, and came across this.
Talk about having hell to compress these bad boys. Has anyone ever seen the inside spring installed with the double spring valve spring. It also has 4 washers,
3 I believe are shims. It has been a long time since I have pulled any down and
my memory is a little fuzzy to say the least. Seems the large flat washer and
double spring is what I remember when pulling these type heads down.
Here are a few pics.
Not original, I can tell the have been off before. There is what looks
like Felpro head gasket material left on them. So is there supposed to
be any washers, or do the springs just set against the head?
These heads came from the factory with the heavy valve rotators, so the thick washer and shims are needed to get the correct installed spring height when you delete the rotators with aftermarket double springs like these.
Sorry, I guess I'm not being clear. The factory springs used with the rotators would have been the outer coil spring and the flat damper ONLY. The springs in your photo show an outer coil, inner coil, and damper. Those appear to be aftermarket springs. The added thickness of the inner coil precludes the use of the rotator, thus the shims and washers are needed to make up the thickness when the conventional thinner retainers are used. Also, since the rotators are much heavier than retainers, they are often deleted to raise allowable RPM.
Where's the crack? My inclination is that they did not contribute, depending on where the crack is located, but I'll defer to the more hard-core racers here.
Yes, I didn't realize Oldsmaniac posted a photo. The OD of the replacement guide is slightly less then the cast iron guide boss. The cast iron guide boss should be completely eliminated though, because it would be very prone to cracking with so little material left for support.
There are plenty of valve seals that fit those aftermarket springs. Why they weren't installed is a puzzle. Viton comes to mind. They are small diameter and press right onto the guide. Unlike umbrella seals they don't ride up and down with the valve.
As stated that cracked guide can just be replaced with bronze ones. No need to scrap those heads.
A word on those shims. There are special spring retainers that are made to sit deeper on the valve stem thus taking up the distance that was originally for the valve rotator and restoring valve spring height. There was no need for all those shims if the machinist had done his job right.
