62 Rear End-Disassembly???????
Old Apr 19, 2010 | 07:25 AM
Natas's Avatar
I pulled the rear end out of my 62 Olds to clean up and have the center-bore on the axles machined down. Having a problem getting the axles out. Do I have to take the bolts off the bearings and they will slide right out? Loosened the center section already. and pulled the pinion. Any help would be appreciated.
Old Apr 19, 2010 | 08:42 AM
Natas's Avatar
I'm assuming undo the four bolts on the axle flange and pull, use the drum as a slide hammer if needed?????????????????
Old Apr 19, 2010 | 09:23 AM
Eddie Hansen's Avatar
I have not worked on a 62 rear but if it is similar to the o type rear , then yes remove the 4 bolts, you should not have to use the drum as a slide hammer, the drums should be off, then the backing plate will come off, I got a cheap slide hammer and kit at Harbor freight, but did not need it to remove the axles. I am unclear how you got the pinionout without taking out the carrier? you can not get the carrier out without removing the axles?
this is the slide puller I bought
http://www.harborfreight.com/cpi/cta...temnumber=5223
Old Apr 19, 2010 | 09:31 AM
Natas's Avatar
Thanks for the response, Just loosend up the bolts to get my pinion bearings out. Didn't remove it. Thanks.
350TurBRO
Sep 12, 2014 11:52 AM
mv213
Apr 17, 2011 04:01 PM
csstrux
Oct 25, 2009 03:23 PM
elcaminodave
Sep 13, 2008 11:25 AM
rocket69
Jun 15, 2008 09:12 PM
