72 cutlass convert rear end swap
Old Apr 18, 2010 | 05:39 AM
crank.it's Avatar
hi guys long time no post,,,,,been working on a 72 cut and have a chance to get a posi from a 78 87 doner just wondering on the fitment into my 72 any thoughts or pitfalls ....thanks crank.it
Old Apr 18, 2010 | 09:09 AM
leadfoot067's Avatar
it wont fit..
Old Apr 18, 2010 | 12:16 PM
svnt442's Avatar
Not only that, IF you were able to get it under the car it wouldn't last too long.
Old Apr 18, 2010 | 04:06 PM
crank.it's Avatar
thanks guys....I measured from brake plate to plate and get like 55 inches...the seller says its 51 inches from plate to plate....why wouldnt it last long????if it did shoe horn it in their...thanks crank .it
Old Apr 18, 2010 | 05:05 PM
First, the 78-87 cars (except for the 84 H/O and 85-87 442 and GN) used the 7.5" rear axle that was originally born under the Vega. THAT"S why it won't last long. Second, the axle is 4" narrower, which means you need different wheels with a non-standard offset to prevent tire rubbing. Third, the upper control arm locations are different on the newer axles, resulting in suspension binding. This is a complete waste of time and money.
Old Apr 18, 2010 | 06:36 PM
kaz442's Avatar
Just find an 8.5" posi carrier out of camaro/firebrid, wagon, or a truck and swap it into your rear. Or contact Brian Trick (507olds) on this board I'm sure he has what you need.
JKaz
Old Apr 19, 2010 | 04:05 AM
crank.it's Avatar
Smile
thanks joe and other posters for the info...the posi was hundred bucks complete thats the reason I was gonna make it fit which you have convinced me it will not....how about a nice eaton etchediam argueing over a hundred bucks then talk about eaton thanks muchly crank.it.....talk at ya soon
Old Apr 19, 2010 | 04:12 AM
OLD SKL 69's Avatar
GM Enthusiast
You can also pm Monzaz as he rebuilds units for these cars and usually has a few lying around ready for sale.
Old Apr 19, 2010 | 11:48 AM
Yeah, the low price should have been a hint...
young olds
Jun 11, 2015 10:41 AM
350TurBRO
Sep 12, 2014 11:52 AM
vistacruiser1971
Nov 9, 2013 01:19 PM
Beeks69
Drivetrain/Differentials
17
Aug 26, 2011 04:41 AM
olds cutlass
Apr 9, 2009 05:44 PM
