72 cutlass convert rear end swap
hi guys long time no post,,,,,been working on a 72 cut and have a chance to get a posi from a 78 87 doner just wondering on the fitment into my 72 any thoughts or pitfalls ....thanks crank.it
thanks guys....I measured from brake plate to plate and get like 55 inches...the seller says its 51 inches from plate to plate....why wouldnt it last long????if it did shoe horn it in their...thanks crank .it
First, the 78-87 cars (except for the 84 H/O and 85-87 442 and GN) used the 7.5" rear axle that was originally born under the Vega. THAT"S why it won't last long. Second, the axle is 4" narrower, which means you need different wheels with a non-standard offset to prevent tire rubbing. Third, the upper control arm locations are different on the newer axles, resulting in suspension binding. This is a complete waste of time and money.
thanks joe and other posters for the info...the posi was hundred bucks complete thats the reason I was gonna make it fit which you have convinced me it will not....how about a nice eaton etched
iam argueing over a hundred bucks then talk about eaton
thanks muchly crank.it.....talk at ya soon
vistacruiser1971
Nov 9, 2013 01:19 PM
