Fusick coolant hose clamps
Old Jul 12, 2019 | 09:22 PM
72cutlass408's Avatar
Has anyone use them for a 68’? I heard good and bads.
Old Jul 13, 2019 | 07:34 PM
70Post's Avatar
If you are referring to the "double wire" style hose clamps which I believe is what your car used originally, then Fusick is likely your best choice.
The only "gripe" I've heard is the two clamps used on the thermo housing bypass hose may be slightly larger than the originals so they end up almost "closing up" completely by the time the clamp is tight. I am NOT aware of anyone making the correct/original sized bypass hose clamps....I think all the repro vendors offer this "slightly oversized" size.
DO NOT use the double wire clamp set from Inline Tube......the clamps are not formed that well and will cause problems when trying to install them. EXAMPLE - I tried installing the Inline Tube clamps on a '70 442 this past Thursday...stock car w/factory 4 row radiator, etc. TWO CLAMPS could not be installed --- one bypass hose clamp was too misformed and would not go over the bypass hose where it connects to the thermo housing. One lower radiator hose clamp would not go on down at the lower hose-to-radiator connection....too small and also misformed.
Ordered a set from Fusick on Friday. I've installed them before and they work and are formed correctly. I have originals here I compared to the Fusick and ILT clamps and YOU CAN see a difference. Just sloppy (or lack of) quality control on the part of ILT.
Not sure if the clamps from The Parts Place work and are made correctly but I checked there and didn't see a complete "kit" like Fusick offers...you had to select individual clamps but I may have used theirs in the past and don't recall any problems.
I'd just order them from Fusick and be done with it (or find nice originals - not an easy undertaking).
Old Jul 13, 2019 | 08:32 PM
Thank you
Old Jul 13, 2019 | 09:08 PM
70Post's Avatar
Hopefully you'll save yourself the swearing, sweating and general PITA-ness I experienced with the ILT clamps by getting the Fusick set.
NOTE: The Fusick set may also include some heater hose clamps....wire "Corbin" type clamps. Not sure what the '68's used on the two HEATER HOSES but these Corbin clamps (the rod/wire material type) can be a real pain to get on over the installed hose - no matter whose clamp set you use. There are special pliers made to help install these Corbin style clamps - here's what they look like:
https://www.homedepot.com/p/GearWren...E&gclsrc=aw.ds
If your car uses the flat band "pinch clamps" on the heater hoses then Fusick's "Corbin" style clamps won't be technically "correct" if that matters.
In this case you can now go right back to the place I said to avoid (ILT) and order just the pinch clamp set (4 clamps) for your heater hoses. They have them in a 4 pack and they work fine and look more original on the HEATER HOSES. Again, I'm not sure which style your year used on the two heater hoses (3/4" and 5/8" hoses). Here's a link to what I call the "flat band pinch clamps":
https://www.ebay.com/itm/68-69-70-CU...QAAOSwtGlZNsbj
Here's an example using a 1970 442:
>Upper and Lower Radiator Hoses - use the double wire hose clamps (4)
>Thermostat Housing Bypass Hose - uses the double wire hose clamps (2)
>Heater Hoses - uses the flat band pinch clamps (4) - I believe some earlier models used the Corbin style....like 64-67....I'm just not 100% sure on '68 cars.
Old Jul 14, 2019 | 08:14 AM
WTHIRTY1's Avatar
Escape From The Ordinary
I picked up bypass hose clamps from The Parts Place last November. They're nice. All the clamps available appear to be "too long."
Old Jul 14, 2019 | 08:40 AM
w-30dreamin's Avatar
71 & 72,now I want a 68
About 8 years back I tried a set of clamps from Fusick,had one leaking at the heater core and one leaking at the radiator.
Tried readjusting them a few times and cleaning the surfaces of the metal parts,could not get the leaks to stop.
Put screw type hose clamps back on,no leaks.
Old Jul 14, 2019 | 11:00 AM
When you say screw type, you mean just the standard ones in production now? I really like the looks of the original but do want function over looks. Thanks for the info.
Old Jul 14, 2019 | 01:58 PM
Yes just a standard type modern hose clamp that uses a screw to tighten. Would it be called worm gear style?
I like the looks of the originals also,makes for a nice period correct look but I like to drive my car so I don't want antifreeze leaks.
Many guys get the older style to work but I couldn't. I'll guess the originals were made better then the modern reproductions.
Old Jul 14, 2019 | 03:14 PM
Decision decisions
Old Jul 14, 2019 | 05:21 PM
junior supercar's Avatar
Patton's analysis is spot on (as always). 68-70 use the pinch style clamps for the heater hoses. originals have square tangs while the ilt have rounded, if those **** restoration details matter.
Old Jul 14, 2019 | 07:28 PM
70Post's Avatar
FWIW - I've installed a few sets of the repro clamps and haven't had any leaking problems. Sure, double check once you've driven the car and heated things up ..... sometimes one or two may need to be tightened a bit further but so far, none have failed me. I could see the ILT bypass hose clamps (and possibly the rad hose clamps) causing a problem with their partially mis-formed wire parts but the Fusick (and likely Parts Place) clamps are formed ROUND....along all the parts of the wire.....so they should seal just fine.
There are A LOT of folks on this site running the repro double wire clamps.
Old Jul 15, 2019 | 09:01 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
72_408,
70 post nails it.
The problem is with the bypass hose is not the clamps. The Fusick
clamps are very nice.
The clamps are made to the old thicker hose OD. Today's hoses are thinner on the OD than the OEM. I've told Fusick about this.
Not sure if the problems been resolved or not.
I have some close-ups showing the difference. Cant find em....
https://classicoldsmobile.com/forums...g-clamp-98643/
Old Jul 15, 2019 | 09:22 PM
70Post's Avatar
I agree on the newer bypass hoses being a slightly smaller O.D. ...but.....I also believe the bypass hose clamps are slightly larger than the originals. In any case, these characteristics for each part exacerbate the problem.
I think I mentioned it on some other thread on this site in the past but I have one bypass hose here that is of a slightly larger O.D. ....slightly thicker walls. Freakin' thing even has the "ribbing" cut into the hose. Unfortunately there is no tag on it but there is a PN or part thereof. I'll grab it and post some info. I also have AC Delco and Dayco versions but they appear to be of the slightly smaller O.D. (bought more recently).
Old Jul 16, 2019 | 07:56 AM
I’m going through all the necessary items so it can be a good driver. I’ve decided to put all the details when I put in my spare #’s matching motor.
Old Jul 16, 2019 | 08:06 AM
Old Jul 16, 2019 | 08:07 AM
Used the Be Cool #17008 radiator
cdoering
Aug 23, 2019 05:20 PM
68442
Aug 10, 2016 03:50 PM
1yesfan
Oct 7, 2014 06:43 AM
tecar442
May 27, 2013 09:46 AM
Del70
Oct 8, 2010 09:21 AM
