fuel line - stock pump to Quick Fuel Slayer carb
Old May 20th, 2016, 03:21 PM
1968_Post's Avatar
I need to figure out a fuel line from the fuel pump to a Quick Fuel dual inlet carb. What complicates matters is I've installed Vintage air and the compressor bracket is close to the outlet fitting on the pump. I'm not sure I have room for a AN fitting unles I can find a 45 or 90 degree fitting to go in the pump. I'm sure I'm not the 1st to run into this... any suggestions? I could get a stock line and cut it, then install the AN's further upstream. Is that the best option?
1968_Post is offline
Old May 20th, 2016, 04:50 PM
They make AN fittings in a lot of configurations including 45 and 90 degree.
oldcutlass is online now
Old May 20th, 2016, 04:57 PM
1968_Post's Avatar
I'd been on Russel's site forever trying to come up with what I needed... I just found a swivel 90 degree AN-6 to 5/8-18 thread that looks like it may work. The remaining question is whether there's room to the a.c compressor bracket to get it in.
Knowing exactly how to refer to the fitting so as to limit the search was the biggest problem. Once I got the terminology correct, things got easier.
1BOSS83
October 11th, 2015 07:58 AM
wcourt3010
May 12th, 2015 02:57 PM
cut123
September 20th, 2013 05:47 PM
rookieoldsguy72
August 26th, 2013 06:43 AM
Red Delta
September 12th, 2010 08:50 AM
Quick Reply: fuel line - stock pump to Quick Fuel Slayer carb
