Fuel inlet threads on a Qjet
best way is a helicoil,not very hard but kind of pricey if you only do it once. there are oversized fittings available and ive seen/used one that has an o ring that worked,but i didnt trust it very long. check with a reputable parts place ,napa or car quest they may be able to heli coil it for you.
Here's a kit: $190.
The question is: How much will someone charge to do this for you?
If their charge is around the cost of the kit, might as well get the kit, and you'll be able to do more carbs in the future for "free" if you ever need to.
It can be done by a carb shop. Check this site http://www.sparkyscarbs.com.
Woudn't happen to be a 7040258 that you want to sell.... I need one.
x3 Sparkys did mine and it came out great!
A had one done by a carb shop in California- yep that Carb shop. They did it crooked! wouldn't seal. I sent it back and got it back still crooked after $60.00 to and from shipping. So be carefull who you have do it. If it's crooked it won't seal because it seals to a gasket on the back side of the filter housing. I had a lot of money in a rebuild for this carb, so I used seal all on the threads and it worked for a while- Since then I got another carb.
