Qjet issue - needle/seat threads
Old Nov 26, 2014 | 12:21 AM
EightballZ's Avatar
hey guys,
i found out my 7040252 Qjet lost its needle/seat threads to the former "rebuilder".
looks like they were shot so he drilled them out to fit in a pressed-in-style seat (2 o-rings).
now i know why it was such a pain in the rear to set float level.
heli coil time or better get a new bowl ?
Old Nov 26, 2014 | 02:53 AM
Wow. I've never seen that before.
If HeliCoil makes that thread, then it would make sense to use it, but I personally haven't heard of it.
I'm suspecting you may need a new float bowl, and it may be easier to just get a whole carburetor.
Old Nov 26, 2014 | 12:30 PM
Those have been around for quite a while. Do a web search for QuadraJet needle and seat repair and they pop up. The ones I saw are going for around $12.
Old Nov 26, 2014 | 12:55 PM
EightballZ's Avatar
http://quadrajetparts.com/rochester-...ads-p-209.html
Old Nov 26, 2014 | 02:39 PM
Guess I've never searched for one, because I've never stripped a seat thread.
Looks like a crappy type of repair to me. I wonder about the availability of HeliCoils in the correct thread.
Old Nov 26, 2014 | 03:41 PM
Sugar Bear's Avatar
The fuel inlet nut in the first picture also looks like a repair type. Might be time for a another carb or fuel bowl.
Old Nov 26, 2014 | 10:01 PM
I've never needed one either, but I spent many years in the auto parts business during high school and college so became aware of them.
Old Nov 27, 2014 | 12:12 AM
EightballZ's Avatar
damn that sucks....especially since this is a matching numbers carb
in case i cant find a correct number body...what carb numbers will fit the baseplate and airhorn?
Old Nov 28, 2014 | 07:35 PM
oddball's Avatar
I'd recommend against just getting a replacement body. The bottom of the body and the throttle plate generally stay flat, but the top of the body and the airhorn warp against each other. It's very, very difficult to get an airhorn and a body that didn't age together to work well together.
If that's the only problem then I'd try the correct replacement needle first. Won't lose much that way.
Old Nov 28, 2014 | 08:54 PM
Not only that, but it will be a lot harder to find just the body than to find a complete carb.
Old Nov 28, 2014 | 09:49 PM
oldolds88's Avatar
i think the seat takes a 3/8 thread. the inlet uses a 1" helicoil make one special for the q jet. kit for the inlet is around 195.00 thru qjet repair parts. or call cliff ruggles and talk with him. 740 3972921
Old Nov 30, 2014 | 02:40 AM
Backstrom's Avatar
Try www.carbguy.com or Kents Qjet.(kentsqjet@hotmail.com) both located in Sweden, not germany but at least inside EU. By far the most experienced q jet rebuilders in europe.
I've had good business with Kent, very helpful and nice guy.
/ Anders
Old Nov 30, 2014 | 05:02 PM
Octania's Avatar
Intersting way to phrase that.
I worked on a 1973 455 a while back... took the air horn off to find that the air horn and/or body mating surface were warped a LOT- like well over 0.100". Yet, the carb behaved well. I did end up replacing it as part of the rebuild I believe.
8-ball, I will look into a carb assembly for you.
Old Dec 1, 2014 | 11:04 AM
EightballZ's Avatar
throttle arm for octania
98regency
Aug 3, 2014 10:40 AM
Bernhard
Dec 23, 2013 07:02 PM
nukesec1
Cars Wanted
26
Dec 5, 2009 12:51 PM
FATRATMATT
Oct 16, 2008 04:21 AM
1965_F85
Feb 15, 2006 11:54 AM
