Fuel gauge is sprung
Old Sep 25, 2023 | 06:03 PM
Oldscutty72's Avatar
Drop the tank on my 72’ cutlass supreme and replaced the sending unit. *plugged the wires back in and turned the key on to check the gauge. Gauge Immediately pegged past Full. Checked the connections and realized when re-installing the tank, I knocked a wire off, plugged it back in and gauge went back to normal so I thought. When tank level gets low, gauge never goes to Empty anymore. Assuming that the gauge is sprung. Anyone else have this issue and is it possible to replace or repair the mechanism?
Old Sep 25, 2023 | 07:33 PM
If you ground the sending unit wire does the gauge go to E? If so, the gauge is likely OK and it’s something else, such as the sending unit float arm may be out of adjustment.
Old Sep 25, 2023 | 09:33 PM
Good info
If you ground the sending unit wire does the gauge go to E? If so, the gauge is likely OK and it’s something else, such as the sending unit flat arm may be out of adjustment.
Thanks Fun71, I’ll give that a try!
andyhen
Aug 22, 2024 05:55 AM
JonnyO
Aug 30, 2021 04:21 AM
sammieolds
Jan 28, 2014 09:08 PM
MHENDERSON
Jun 28, 2013 08:30 PM
Last98
Nov 29, 2011 10:37 AM
