Gas gauge and tank question?
Old Jun 28, 2013 | 07:17 PM
MHENDERSON's Avatar
I just put a new gas tank and sending unit in my 1970 Olds cutlass Supreme.The gauge read 3/4 before I started and when done it sayed the same?I did hook up the ground wire comming off the tank.The tank I bought has 3 other lines comming off it.I pluged all 3.when I unscrew the gas cap I have air pushing out.Any help would be so nice,thanks!
Old Jun 28, 2013 | 08:19 PM
jaunty75's Avatar
Have you verified the gauge is not just stuck? With the gauge disconnected from the tank at the rear of the car, ground the side coming from the gauge and turn the key on. The gauge should immediately go to E. Remove the wire from ground, and it should immediately go to F or past it. If it does those things, the gauge is fine.
But I'm suspecting that, with a new sending unit, if properly wired, and the gauge has never moved from 3/4, you have a stuck needle or an electrical problem right at the gauge that replacing the sending unit did not address.
Old Jun 28, 2013 | 08:30 PM
Did you install a vented or non-vented cap?
Have you checked the voltage supply to your gauge and the connection between the gauge and the sender?
There are a number of threads here where fuel gauge troubleshooting is discussed in detail, such as here, here, and here.
joemo
Sep 21, 2022 04:47 AM
RG1970
Aug 15, 2015 11:03 AM
illumined
Aug 7, 2014 07:21 PM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
