Gas gauge and tank question?
I just put a new gas tank and sending unit in my 1970 Olds cutlass Supreme.The gauge read 3/4 before I started and when done it sayed the same?I did hook up the ground wire comming off the tank.The tank I bought has 3 other lines comming off it.I pluged all 3.when I unscrew the gas cap I have air pushing out.Any help would be so nice
,thanks!
,thanks!
Have you verified the gauge is not just stuck? With the gauge disconnected from the tank at the rear of the car, ground the side coming from the gauge and turn the key on. The gauge should immediately go to E. Remove the wire from ground, and it should immediately go to F or past it. If it does those things, the gauge is fine.
But I'm suspecting that, with a new sending unit, if properly wired, and the gauge has never moved from 3/4, you have a stuck needle or an electrical problem right at the gauge that replacing the sending unit did not address.
illumined
Aug 7, 2014 07:21 PM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
