Fender Question
Old Jul 10, 2011 | 09:23 AM
oldsguybry's Avatar
NOVICE car nut
Fender Question
is it possible to remove either fender without removing the hood ? I need to remove fender in order to get the inner fender support off and clean up the rust .... and if anyone could tell me how many spot welds i have to remove i would appreciate it. thanks in advance
Old Jul 10, 2011 | 10:12 AM
Nilsson's Avatar
No shortcuts remove the hood.
Old Jul 10, 2011 | 01:53 PM
69442C's Avatar
Actually, you can leave the hood on. You'll need to use a prop rod or 2x4 to hold the hood open in the front and then use a section of 2x4 about 12" long that you will place on top of the cowl, under the rear edge of the hood,near the fender, when you unbolt the hinge. That smaller 2x4 will hold the hood up similar to how it would be if the hinge was supporting it. You'll want to make sure the hood doesn't slide on this block. I believe we used to have that block sit on the cowl and then partially up the windshield. Also make sure the front support is firmly in place. If you plan to have the fender off for an extended period of time and the car will be sitting in an area where people or kids could be passing by frequently, them remove the hood to be safer.
Not sure on the number of spot welds to remove that brace but it's probably about 12-14. I think there are 4 or 5 along the bottom, 3 at the top and maybe around 5 along the back edge.
Old Jul 10, 2011 | 02:35 PM
X2. I think it would also be a lot safer in the long run especially when you are remounting the fender.
Old Jul 10, 2011 | 07:56 PM
oldsguybry's Avatar
NOVICE car nut
Thanks...... I had the hood off a few years ago and remember how heavy it was , was trying to avoid it , but we will see in a week or so when I borrow my moms garage to take fenders off.... I will post some pics on the process.
Old Jul 11, 2011 | 04:13 AM
69442C's Avatar
Originally Posted by oldsguybry
will see in a week or so when I borrow my moms garage to take fenders off.... .
If you are going to remove both fenders, then the hood needs to come off. If you remove just one fender at a time, you can do as I mentioned earlier.
Daverd
Dec 31, 2013 04:15 PM
ohiocutlassparts
Dec 9, 2013 05:58 PM
442iowa
Jun 4, 2013 04:52 AM
Nufo
Feb 15, 2013 10:30 PM
72rocket
Sep 24, 2007 07:14 AM
