Fan rubbing on lower end of shroud
Old Sep 3, 2019 | 06:17 AM
Bfg's Avatar
Bfg
I have a 65 442 with factory a/c. Car is all stock. I’m finally getting the car put together and on start up the fan is rubbing on the lower end of the fan shroud. Oiriginal radiator. It looks like the shroud is not centered in the shroud. Radiator is sitting correctly in the core support. The whole front clip was removed off the car. Could the core support need further adjustment to illiminate any rubbing. I know I have to have everything loose when I align the fenders. Am I on the right track? Any advice?
Old Sep 3, 2019 | 08:21 AM
AJFink's Avatar
(Could the core support need further adjustment to illiminate any rubbing.)......I would say most likely,
Do you have a factory assembly manual? and the CSM? If not it would be best to have these. Chances are you have the core support shimmed too high, Have you changed your motor mounts?.........Do you have the right motor mounts?
Old Sep 3, 2019 | 08:35 AM
It could be a few things, as stated above the core support is shimmed too high, engine mounts are sagging, trans mount too high, shroud mounted wrong, etc...
Old Sep 3, 2019 | 09:57 AM
Bfg's Avatar
Bfg
Thanks for your reply’s. No shims were installed in the core support. Original motor mounts. Shroud only mounts in one location. I used a trans mount from a automatic trans. Car is now 4 sp. Is there a difference between the two mounts?
Old Sep 3, 2019 | 01:24 PM
yachtsmanbill's Avatar
Did you change out the core support rubber bushings? Are they in the correct sequence? Usually, the shrouds hook on the bottom on the lower cross bar, and if thats too high, the shroud will be too. Did you change the core support too??? ws
Old Sep 3, 2019 | 04:39 PM
RetroRanger's Avatar
72 Olds CS
Mine rubbed until i changed out the original motor mounts w new ones
Old Sep 3, 2019 | 06:37 PM
Bfg's Avatar
Bfg
I used the same core support bushings. I will take a look and see what I can find.
Old Sep 4, 2019 | 02:23 PM
I have found I need to replace motor mounts about every 3-4 years. These newer chinisem cheap mount sag, I would try new mounts first-they're cheap. Let us know how it comes out..
Old Sep 4, 2019 | 06:38 PM
Bfg's Avatar
Bfg
There was no problem with the fan rubbing prior to disassembly. So I don't think it could be the motor mounts. I have never heard of changing the mounts every 4 years. I'm thinking it could be the core support or rubber bushings under the radiator.
matt69olds
Apr 13, 2020 07:45 AM
kevdog442
Mar 19, 2018 06:28 PM
dream66
Apr 30, 2017 04:31 PM
Markopolo1
Jan 25, 2013 08:01 PM
Bunser
Apr 30, 2010 10:20 AM
