Adding fan shroud problem
Old Apr 29, 2010 | 10:46 AM
Bunser's Avatar
I would like to add a fan shroud to my 70 Cutlass.It originally came without one.Do I have to get a different core support by any chance to add a shroud? What confuses me is, the original top plate has two holes matching the two top holes on the fan shroud, but there are no mounting "tabs" on the core support for the bottom shroud mounting points. Any advice appreciated.
(Correctionriginal top plate had no matching holes for the shroud.)(Too many conundrums to figure out causing lapses in memory.)
Old Apr 29, 2010 | 12:04 PM
Shizzy's Avatar
they are just simple tabs on the core support of my 72. can you simply add a set that would work?
is this a numbers matching type car or simply a driver?
Old Apr 29, 2010 | 03:19 PM
Bunser's Avatar
It's numbers matching and yes it appears that the tabs can be added and there will be just enuf clearance.( My scumbag bodyman wannabe, damaged the rad and now I have a 4 row rad with my old tanks...used to be a three row according to the rad shop.){I paid the repair bill...don't ask!}
Old Apr 29, 2010 | 04:03 PM
Dave Siltman's Avatar
The tabs are available from Motor City Supercars. A.K.A. Inline Tube. Is your car a W31? Without a shroud?
Old Apr 30, 2010 | 03:11 AM
Bunser's Avatar
Yes, it's a straight from the factory W31.Yes, it came without a shroud and the mounting tabs.I kinda think it should have had one, but maybe with our cool Canadian weather they thought I didn't need one?
Old Apr 30, 2010 | 03:30 AM
Bluevista's Avatar
Registered
It gets plenty hot in Canada, been there a few times in the summer.
A W-31 should have a fan shroud and a four row radiator stock. Something's not right.
Old Apr 30, 2010 | 10:20 AM
Bunser's Avatar
Hmmm...a rarity!I too thought that I should have a fan shroud, so I'm installing one! I'm also of the opinion that H.D. cooling systems were installed on cars with 3.91 to 5.00 axle ratios or air conditioned units.(I've already been wrong once today, may as well make it twice!)
*W31 Heavy duty rad ( included with G92 and G88 axle.)*
*4.33 to 5.00 axle ratio must have been "five" row* jk
Therefore, GM owes me a four row rad and a shroud complete with tabs! LOLZ!!!
Last edited by Bunser; Apr 30, 2010 at 11:25 AM. Reason: Correcting 2nd mistake of the day.
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
sixty9olds
Aug 26, 2009 05:08 AM
