f-150 issue with electrical
Old Sep 11, 2016 | 09:40 AM
truckman5000's Avatar
W30
Hello,
My truck for the last year has been having lots of problems.
Started out if the truck sat for a day, the battery would die.
**I replaced the door switches.
**Replaced the alternator and battery just because.
Then after acouple months, truck would loose all power intermittently.
Like run into a store, come out truck wont start. Put the battery charger on, it would fire rite up.
When the above would happen, the battery is 12v.
The trucks ignition would just click, like the battery is completely dead.
**Cleaned all grounds, checked connectors.
Now, it seems like im at square one.
If the truck sits for a day, its dead.
**But now, while driving intermittently all the interior power will shut off and on.
The truck still drives.
When the power comes back, the truck drives like the computer is "learning" (like when you re-set the computer).
IS there hidden grounds for the PCM?
Do i need a new PCM?
Thats my only next guess...
Old Sep 11, 2016 | 10:11 AM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
year?
Old Sep 11, 2016 | 10:14 AM
W30
sorry
2006
Old Sep 12, 2016 | 07:00 PM
quaddriver's Avatar
4 Barrels of Laughs
typically when I see the words 'let the xxx sit for a day and the battery will die' I tend to blame the alt diodes reverse conducting. As they heat it increases to a steady state of 5-8 amps usually. but you say you replaced that.
we need an inventory of parasites.
an ammeter of sufficient robustness between the battery cable and the battery with everything off, and look for a parasite - anything over say 200mA.
Once you see it, start yanking fuses (hood light off please)
and if that dont help, fusible link time. You will need the chassis electrical manual.
and....by any chance is the fuel pump still running, when the truck is off?
Old Sep 13, 2016 | 05:33 AM
wr1970's Avatar
Is this a 5.4 engine?
Old Sep 13, 2016 | 09:43 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
http://www.ford-trucks.com/forums/index.php
Post your Q ^^^here too^^^. In the F150 or electrical forums. Only in one or the other place not 2x.
How many miles on it?
Grounds Grounds Grounds. Do the below service to all secondary(large) battery cables from the battery through the starter solenoid down to the starter. Clean the small ones coming off the large ones attached to the body as well.
Remove cables, clean, Ohm out (for low resistance and replace is needed), tighten, spray battery protectant on all connections. Find the engine ground strap and do the same.
Bench test the starter.
Check charging voltage and alternator connections.
You live in the north east. Rust is likely under everything.
Do you have FCC cab lights? If so check for leaks. Could be getting behind the dash. Windshield too. Does the cab leak at all(carpet wet or musty?). If so look at the GEM module (If equipped) for evidence of water staining. Known problem but not sure the 2006s have a GEM? Think it went to a VSM module in 04. FTE site will answer that.
Regardless Now that we have the basics covered see if this fixes it. If not move to the deeper stuff if needed...like a voltage drop test....The FTE forum is as much help as this form is.
Old Sep 13, 2016 | 11:43 AM
W30
Thank you, seems like i fixed it
1- harness in engine bay
1- short on trailer plug
Old Sep 13, 2016 | 11:49 AM
quaddriver's Avatar
4 Barrels of Laughs
the short on the trailer plug is interesting....there is a fix/preventative medicine I have used on tow installations for decades -
on the 7 blade plug (pretty much standard for rvs and utility) the ground and the battery charge lines are at the bottom...if you get something in there conducting like water, moist dirt etc, you flow current.
What I do on all my installs (and I learned this from a friend who has an RV sales biz) is to rotate the socket 90* counter clockwise, so the cap 'door', 'lid' whatever, opens up to the drivers side. everything works just fine, but now gravity is your friend
ChefDeadpool
Dec 26, 2010 07:55 AM
jpaulwhite
Aug 21, 2010 06:08 PM
dhartley72
Mar 15, 2010 08:12 AM
blueolds68
Feb 9, 2010 06:55 AM
4speedBench
Aug 13, 2009 04:36 AM
