Exhaust system help needed
Old Sep 13, 2010 | 01:32 PM
WTony's Avatar
Does anyone know who makes a complete 2 1/4 aluminized or stainless, mandrel bent exhaust for manifolds for a 69 442 ? I want 2 1/4 down pipes and tail pipes. I think 2 1/2 will be too big and not look right under there?
Thanks!
Old Sep 13, 2010 | 01:37 PM
wmachine's Avatar
Trying to remember member
I believe Gardner http://www.gardnerexhaust.com/ makes the most "correct" system you can buy, from everything I can gather. Pricey but "the best". (No personal experience)
Old Sep 13, 2010 | 02:10 PM
WTony's Avatar
Kurt I saw those exhausts, but they are only 2" tail pipes. I want something a little less restrictive that sounds better than stock. The car is not really a prestine show car and I drive it, so Im not really worried about it being totally correct.
I just recently re-disscovered how much I really do enjoy driving it.
Old Sep 13, 2010 | 02:26 PM
Thanks!
Tony,
I'm pretty sure nobody makes 2 1/4" mandrel bent. You can get the factory-correct pipes (which are not mandrel bent and which have 2" tail pipes, as you point out) or you can get aftermarket mandrel bent 2 1/2" or 3" systems.
If you want something that LOOKS factory correct, you can use the 2 1/4" tail pipes from a 1970 GTO. These will need some mods at the ends to get the trumpets to fit the bumper, but the only other alternative is custom bent.
Old Sep 13, 2010 | 03:48 PM
Run to Rund's Avatar
Check Torquetech and Pypes. 2.5" won't look much different and will flow around 20% more air.
Old Sep 13, 2010 | 04:50 PM
wmachine's Avatar
In that case, 2-1/2 inch by all means!
Old Sep 13, 2010 | 05:47 PM
TripDeuces's Avatar
Torque Tech makes down pipes kits for manifolds. Here's the Olds ones. I couldn't find where it said what size it is.
http://www.torquetechexh.com/Web%20Photos/GM%20Non2.jpg
Old Sep 13, 2010 | 06:33 PM
firefrost gold's Avatar
I think inline tube has some stuff too I would also look a ram air restorations .
Old Sep 14, 2010 | 06:37 AM
If your car is a driver and you don't race it or show it then just have a local exhaust shop install new pipes. I had 2.5 inch aluminized pipe installed on my 71 98 with a cross pipe and tips for about $300. The HP loss from running non mandrel bent pipes is completely undetectable with my "butt-dyno."
Old Sep 14, 2010 | 06:59 AM
66ninetyeightls's Avatar
Land Yacht Captain
Man I need to move to the US. Everything is so much cheaper down there. The cheapest I got quoted up here was $600
Old Sep 14, 2010 | 09:41 AM
Does that price include the mufflers? The $300 I paid didn't include about $150 I spent on two 45" Thrush glasspacks. I bought them from the auto parts store.
Old Sep 14, 2010 | 10:07 AM
Land Yacht Captain
Yeah thats it. It did include mufflers.
71Oldsmobile
Apr 10, 2012 10:11 AM
ragtop71
May 4, 2011 04:25 PM
silverriff
Sep 30, 2008 03:30 PM
smason
Dec 7, 2006 10:55 AM
