engine squeal
Old Nov 12, 2023 | 03:03 PM
tkcutlass's Avatar
engine squeal
In the last week or two, I have started this engine a couple dozen times or so. (Broke in and dynoed last year)
Last night I added some more transmission fluid and ran it through the gears and it seemed fine.
Today I wanted to actually have the car move under its own power.
I fired up the engine only to hear a loud squeal.
Ok Probably got antifreeze on one of the belts.
Proceeded to tighten all the belts and still loud squeal.
Loosened all the belts... and hmm still loud squeal.
The power steering pump seemed like it could spin more freely.
Almost had it out and retested it seemed fine.
So put everything back together tightened the belts and.... squeal
I removed all the belts and fired the engine for 5-10 seconds and still squeal..... I checked for oil pressure.
Do I have big trouble?
spun bearing?
transmission?
what else can make such a squeal when no belts are attached?
I am very concerned and confused.
What's the best approach to troubleshoot this?
Old Nov 12, 2023 | 03:17 PM
Sugar Bear's Avatar
Vacuum leaks can make a loud squealing noise, its not common but I've seen it 2-3 times.
Old Nov 12, 2023 | 03:21 PM
Does the squeal resemble that of Ned Beatty? I'll just grab a cookie on my way out...
Old Nov 12, 2023 | 03:32 PM
66_Jetstar's Avatar
I had a vacuum hose that would collapse. That squealed like a stuck pig. That took some figuring to find out.
Old Nov 12, 2023 | 04:13 PM
tkcutlass's Avatar
Weird I just put the belts back.
Fired it up it squealed for a few seconds then stopped.
Seemed fine shut it down and started again quick squeal then ok.
Seemed like a scrapping noise.
I think maybe torque converter to the flexplate may have loosened up.
Old Nov 12, 2023 | 04:42 PM
442Harv's Avatar
Did you change the tran filter? If so, did you seat the pickup tube good? If not it will suck air and squeal.
Old Nov 12, 2023 | 05:25 PM
tkcutlass's Avatar
New install/full restoration.
Sounds more like a metal-to-metal scraping sound to me.
Old Nov 12, 2023 | 05:45 PM
Did you say the PS pump seemed tight? I might go with that. I once had a PS pump making a noise like that and I didn't figure it out until it was nearly seized, I mean to the extent that the engine was overheating from the extra drag.
Old Nov 12, 2023 | 05:52 PM
tkcutlass's Avatar
I was fairly convinced it was the PS pump until I removed all the belts and it still squealed/Scraped
Old Nov 12, 2023 | 06:04 PM
Okay, then. Gotta stethoscope?
Old Nov 13, 2023 | 03:39 AM
Oldsguy's Avatar
Past Administrator
https://bitmidi.com/dueling-banjos-1-mid
Just click on the option to play it.
Old Nov 13, 2023 | 04:36 AM
Did you put a double row timing chain in it? I remember I had some issue when I put one in- had to apace out or shim pump or?? Really can't remember. I wonder if it hits at times if that is it??? I hope that isn't it....
Old Nov 15, 2023 | 07:01 PM
tkcutlass's Avatar
Had some time to troubleshoot the squeal.
Fired it up and I got the squeal again a few times and almost threw my hands up and thought I might have to check the timing chain.
I took a look at the clearance of the flexplate to the starter gear and noticed it was pretty close.
Tried once more and actually saw the problem. The starter gear was intermittently hitting the flex plate.
I am wondering if the recent drop in temp is enough to shrink the tolerance.
Now I am a little confused about shimming the starter doesn't that change the tooth depth as opposed to the distance from flexplate?
At least it's not an engine problem.
Old Nov 15, 2023 | 07:31 PM
tkcutlass's Avatar
Looks like this is what I need,
Old Nov 16, 2023 | 02:47 AM
Glad you got it figured out, should be a easy fix.
Old Nov 16, 2023 | 03:51 AM
That big round shim is usually included with the starter.
Old Nov 20, 2023 | 06:26 PM
tkcutlass's Avatar
The shim arrived today so I dropped the starter and hmm it already had a shim installed.
It says not to use more than 1 shim.
I did notice 1 of the hex screws was loose since it did not squeal for the first 2 dozen starts I am thinking that's the problem.
I guess if the loose screw allows the starter to pivot it won't take much to hit the flywheel.
I think they have a .08 shim vs standard .062.
Old Nov 25, 2023 | 06:38 PM
tkcutlass's Avatar
Spoke with Powermaster support and they said I could use two shims if need be.
Figured I'd try with one shim properly tightened, inch lb torque wrench showed up today so I gave it a shot, and ng it still squealed.
Installed the second shim and seems to be good now. Only started it once or twice. since the second Shim went in.
Old Nov 25, 2023 | 07:03 PM
Make sure you are using knurled starter bolts to keep the starter from twisting.
Old Nov 26, 2023 | 10:15 AM
tkcutlass's Avatar
Yes, I used the knurled bolts that came with the starter.
olds 307 and 403
Oct 10, 2016 07:07 PM
steverw
Aug 18, 2015 05:32 PM
70-442-W30
Jul 6, 2015 04:29 AM
Joeypete
Feb 2, 2010 06:58 PM
stevengerard
Sep 26, 2009 08:59 AM
