engine compartment ac unit
Old Apr 24, 2023 | 11:10 PM
blp's Avatar
blp
is it ok to remove from firewall ac unit and still have a heater // 1968 cutlass
Old Apr 25, 2023 | 04:18 AM
don71's Avatar
same but different
No. It will require the non a/c air box OR a modification to the existing box in order to move heated air into the cabin.
https://www.summitracing.com/parts/o...xoCSJ0QAvD_BwE
Old Apr 25, 2023 | 05:01 AM
You can remove the evaporator from the AC box and then seal the AC box. You'll be able to run vent & heat with your OE AC controls.
Old Apr 25, 2023 | 05:32 AM
As noted above, the box on the firewall provides the airflow path from the blower motor to the heater core and vents in the car. You need something there - either the original HVAC box or an aftermarket "A/C delete" box. Also keep in mind that on A/C cars the flapper doors in the box under the dash are operated with engine vacuum, which means that you need to retain the original A/C control panel and the vacuum hoses and reservoir (ball) on the engine side of the firewall.
Old Apr 27, 2023 | 01:55 AM
blp's Avatar
blp
thank you sir.... very appreciated
Old Oct 14, 2024 | 06:20 AM
walter244's Avatar
Thank you for your response and knowledge
442crzy
Jan 23, 2020 05:33 PM
69442murph
Jan 20, 2016 03:57 PM
crholds442
Tech Editor's Desk
Apr 3, 2014 10:54 AM
snylften
Feb 5, 2014 05:05 PM
mdfedewa
Dec 2, 2012 08:49 PM
