electrical problem, please HELP!
Old Sep 9, 2018 | 08:01 PM
steverw's Avatar
So today i put on a new Edlebrock intake and a Quick Fuel carb. In the process of getting things hooked back up the Alternator wire grounded out on the intake briefly. So now my previously working fuel gauge is pegged all the way on full, and the Gear Vendors OD is not working. This was only at the end of all day working on it, so i was too tired to search for the problem. I know theres a fuse for the GV OD, not sure on the fuel sender. Any ideas that might help? Could it have fried the sending unit? Everything else works, lights, radio. The AMP meter shows to be charging.
Any help would be appreciated.
Steve
Old Sep 10, 2018 | 05:31 AM
edzolz's Avatar
It probably blew both fuses. Don't know why the entire circuit wouldn't blow fuses if you had a direct short to ground with 12 volts. Check all of the fusible links also.
Old Sep 10, 2018 | 05:45 AM
dc2x4drvr's Avatar
I always disconnect the NEG battery cable before doing any work that might involve the electrical system..
Old Sep 10, 2018 | 06:44 AM
^^^THIS! The fusible link is supposed to blow out in a situation like this.
Old Sep 11, 2018 | 07:24 PM
Generally if the fuel gauge goes pegs full its getting power but missing the signal from the sending unit. With the key on grounding the sending unit wire should make the fuel gauge go to E.
Chris Cutty
Apr 22, 2018 08:01 AM
Railguy
Jun 15, 2015 10:50 AM
classicjoe
Sep 6, 2011 08:04 AM
doubletour
Aug 19, 2011 12:18 AM
