Edelbrock intake swap
Old Dec 5, 2018 | 10:03 PM
asscutl's Avatar
I recently put a new edelbrock performer intake in my 72 cutlass 350. I also have a edelbrock 600 cfm carb on it. I don't know what I was expecting but I really didn't notice anything at all power wise and it didn't run as smooth as it once did with the stock intake. Is it possible I need the carb to be adjusted?
Old Dec 5, 2018 | 10:12 PM
76olds's Avatar
Hookers under Hood
Not much to gain with the Edelbrock performer other than shedding some weight. What other mods have you done ? How much performance are you wanting to gain ? Usually the 1406 carb runs ok out of the box but you may want to add a 1 " 4 hole spacer .
Eric
Old Dec 6, 2018 | 12:17 AM
Levellord's Avatar
Running the same combination as you do with the same result. No noticable improvement in terms of power, but this wasn´t my focus so I don´t mind.
But i am also running the carb out of the box.
Old Dec 6, 2018 | 05:02 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The Edelbrock carbs aren't great, many have issues. I would have put on a 625 cfm Street Demon, if I wanted a shiny new carb. Put your Qjet back on, it was designed for your stock 350.
Old Dec 6, 2018 | 05:44 AM
Any carburetor that is installed on an engine needs to be tuned properly with a tachometer and vacuum gauge.
mefirst72
Aug 20, 2021 11:30 PM
OldsManNJ
May 23, 2012 08:20 AM
A72CUTLAS
Jul 27, 2009 08:32 PM
72CUTTY
Nov 3, 2007 05:57 PM
Chumley
May 24, 2007 09:39 AM
