Dupicolor Gold engine enamel is a good paint remover
Old Apr 19, 2017 | 08:54 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I am painting the valve covers for my 70S. I painted them with Rustoleum Aged Copper. It is high temp but not very gas resistant. I cleaned with brake clean and lightly sanded. When the Duplicolor Gold engine enamel was sprayed on top, it peeled the Rustoleum pretty bad underneath, weird.
Old Apr 19, 2017 | 09:17 PM
coppercutlass's Avatar
Chevy budget Olds powered
Whats the main solvent between the two ??? The duplicolor reactivated the rustoleum. Much like when you spray a urethane over a lacquer finish the solvents in the urethane will re activate the lacquer finish. In the automitive refinishing world you would use a waterborne primer to isolate the two or spray very very thin films until you got the desired finish. The over saturation of solvents is what will re activate the paint and make it wrinkle.
Old Apr 19, 2017 | 11:34 PM
Makes sense, I will have to take a look. Obviously the GM factory paint is different.
Old Apr 20, 2017 | 03:07 AM
Like Copper said you have 2 incompatible paints. You need to strip all the paint off and start over.
Dan K
Aug 16, 2016 06:19 AM
hawks70
Paint
Oct 4, 2013 02:47 AM
fatboy578
Apr 17, 2011 07:31 PM
RAMBOW
Mar 14, 2010 07:44 AM
jensenracing77
Paint
33
Jul 30, 2009 07:42 PM
