Dual gate ques.
Old Mar 23, 2010 | 11:03 AM
ELECMAN's Avatar
Dual gate ques.
Im trying to find out the purpose of the manual side of the shifter.can it be used for normal driving or only used for strip racing.if its used as normal driving to is there a certain speeds to shift between gear 1,2,3 i have a 455ci engine with a th400 tranny.thanks for the replies guys.
Old Mar 23, 2010 | 11:35 AM
mugzilla's Avatar
is Fast Enough ...
Put tranny in drive floor it and notice shift points ...
Manually shift at a higher point, stock engine 4.5Gs', comp 6Gs'+...
There are pressure/heat generation differences with manual shifts so watch your temp...
Do you have a shift kit ..?
Old Mar 23, 2010 | 11:41 AM
ELECMAN's Avatar
No is that the one with a shift light i have a aftermarket tach in the clock spot.
Old Mar 23, 2010 | 11:53 AM
mugzilla's Avatar
is Fast Enough ...
I mean a tranny kit ...
Does it patch out on the second gear shift under wide open throttle in drive and what is that shift point in rpm's ...
Old Mar 23, 2010 | 12:14 PM
firefrost gold's Avatar
The his side was so you dont get to exited and over shoot the next gear or into nutural . The shift point is all speculation and feel if you over rev it it will A fall off power and B could hurt your 455 .
Old Mar 23, 2010 | 12:43 PM
Here's a little more basic response. Both gates put the shift cable (and thus the manual selector lever on the trans) in exactly the same place. Selecting low on the left gate is no different than selecting low on the right gate. The only difference, as noted above, is that the right hand gate has internal stops so you can't overshift when manually moving the lever from low to second and from second to drive. This is important when racing, but the transmission neither knows nor cares if you are doing this with the lever in the right gate or the left gate. The bottom line is that you can drive any AT car exactly the same way by manually shifting (even a column shift car). The only difference is that if you are trying to shift a regular shifter too quickly, you can overshoot and hit neutral. This will NOT help your elapsed time...
Old Mar 23, 2010 | 01:39 PM
The Stickman's Avatar
So that's why my car runs hotter when I shift manually.
Old Mar 23, 2010 | 02:46 PM
Only if you are holding it in gear longer that when it shifts automatically. If you shift at the same time as the trans would on its own, there there is no thermal difference. If you hold it in gear longer, you generate more heat in the trans AND more heat in the engine, due to higher RPMs at the same speed. An added factor is that you're running the engine at a higher RPM but driving at a lower than normal speed for that RPM, so airflow through the radiator is also reduced.
Old Mar 23, 2010 | 03:28 PM
BlackGold's Avatar
I'm not as afraid of hitting neutral as I am of hitting reverse ....
Been there. Done that. Paid for it.
Note to self: When staging at the dragstrip, make sure you really do have it in the manual gate and not just think you do.
Old Mar 23, 2010 | 03:39 PM
stlbluesbrother's Avatar
Question
Nice explanation. Now this noobie (me) understands the basics of the Dual Gate behavior.
Question: who in their right mind would drive a car in Low ? Isn't that gear for serious torque needs? Such as pulling a trailer? I've always been tenative to use that gear on any AT car.
Old Mar 23, 2010 | 03:40 PM
Just like a locomotive put the coal to her and she will make some smoke
Old Mar 23, 2010 | 04:31 PM
Bluevista's Avatar
Registered
My GTO has one, haven't used it in the "His" mode ten times in 15 years.
It gets rubber in all three gears now, why worry about shifting?
That's why they call it an "automatic".
Old Mar 23, 2010 | 07:16 PM
mugzilla's Avatar
is Fast Enough ...
Wink
Here's a little more basic response.\
When I manually shift I am holding the shift ...
I had thought there was a different circuit ...
Old Mar 23, 2010 | 08:10 PM
svnt442's Avatar
Nope. It's all mechanical in the shifter.
Old Mar 23, 2010 | 08:52 PM
Makes sense now that I think about it just didn't think it would be that noticeable. My car seems to like to rev out and until I get the EFI working I gotta deal with my carb issues so easier to bang thru the gears than deal with it being a slug.
Old Mar 23, 2010 | 10:32 PM
mugzilla's Avatar
is Fast Enough ...
Another leadfoot tuneup ...
Old Mar 24, 2010 | 09:59 AM
87cutlas's Avatar
stock so far
lol, i put a full manual valve body in mine, so i have to shift every gear, a pain, especially in town. and i did notice more heat afterwords, i just figured it was the increased line pressure/more friction factor inside the tranny
ELECMAN
Sep 2, 2010 04:41 PM
ELECMAN
Feb 17, 2010 07:23 AM
ELECMAN
Feb 13, 2010 03:08 PM
ELECMAN
Nov 30, 2009 09:26 AM
