Dual gate turbo 400 ques
Dual gates are fun and look cool. Before I had my 4 spd Vette I shifted the dual gate all the time. Since owning a V8 4 spd, I only shift every once in a while and like the idea that I don't have to.
Maybe you're thinking of down-shifts. If you move the lever from 3 to 2, or 2 to 1, it won't down-shift until the speed is safe for the engine.
As far as the original question is concerned, when you manually shift -- up or down -- you are using different "circuits" inside the transmission and different mechanisms (bands, clutches) to perform the shifts. By definition, if two things are different, one will wear worse than the other. But I can't tell you which is worse. I suspect, however, that the manual shifting will always wear the transmission more, since you tend to shift up later and down sooner than the transmission would if left to its own devices.
They aren't supposed to upshift according to the manual , it's supposed to stay in first so low gear could be used for engine braking.
This WAS, in fact, a built in feature of the TH400 (at least the early Chevrolet ones) and was an override that would upshift into 2nd at a certain high rpm regardless of selector position. I'm not sure if the later ones (or BOP ones) operate this way. I also just had a conversation with a tech at Kotman's Transmissions who said it is actually better for the trans to shift manually. Go figure.
When I had a TH400 built a 15 years ago they guy disabled that feature, so it can be removed. In fact it would need to be removed for a lot of drag racers. Can you imagine an engine that turns say 7000 rpm being forced to shift to 2nd at say 5500?
ah64pilot
May 29, 2012 03:04 AM
