Drum To Disc Brake Conversion
Old March 18th, 2015, 10:02 AM
akins2000's Avatar
Hello i have drum brakes on my 72 cutlass with a power brake booster do i still need to change the proportioning valve and booster
akins2000 is offline
Old March 18th, 2015, 10:18 AM
Beer Connoisseur
70cutty's Avatar
Yes you will need a disc/drum proportioning valve if you are doing front disc/rear drum. You should also get a bigger master cylinder for disc brakes.
70cutty is offline
Old March 18th, 2015, 10:39 AM
akins2000's Avatar
Ok I have drums on the front. What will happen if I dont change the proportioning valve. Is it really worth changing them over to disc. Just asking.
Old March 18th, 2015, 11:22 AM
Beer Connoisseur
70cutty's Avatar
Here is a link that explains everything.
To me it was worth it. I like to have the stopping power of disc brakes. Some may argue that there was not much difference, I think disc brakes are big improvement over drums. JMO.
70cutty is offline
Old March 18th, 2015, 07:50 PM
nsnarsk65cutlass's Avatar
The rears grab a little,you may not notice it unless on gravel.I put front discs from a monte on a 68 chevelle wagon nothing else.Stopping power is so much better.
nsnarsk65cutlass is offline
Mocephus
October 1st, 2021 09:45 AM
1971viking
October 9th, 2018 04:23 PM
1956olds88post
Brakes/Hydraulic Systems
August 22nd, 2013 06:33 PM
crholds442
December 28th, 2011 07:16 PM
sleeton
November 5th, 2009 01:58 PM
Quick Reply: Drum To Disc Brake Conversion
