do they fit
Old Jul 1, 2012 | 06:03 PM
sparkymark's Avatar
do they fit
will 68 toro hinges fit on a 68 cutlass? or anyone know what will fit on 68 cutlass
Old Jul 1, 2012 | 06:34 PM
sparkymark's Avatar
what will fit
Old Jul 1, 2012 | 07:17 PM
Cutlass hinges will fit.
Old Jul 1, 2012 | 07:25 PM
sparkymark's Avatar
cant find cutlass hinges I know of a set for torobut their in e bay they look the same just didn't know if anyone knew
Old Jul 1, 2012 | 07:40 PM
rocketraider's Avatar
Oldsdruid
Parts book shows 68-72 Cutlass use the same hinge part numbers. They are different right to left and upper to lower. Toronado is a completely different part number. Not saying they won't work, but if they have a different p/n odds are there is a difference somewhere.
Wasn't somewhere reproducing Chevelle hinges? They, or any other 68-72 A-body car should be identical.
Old Jul 2, 2012 | 05:08 AM
allyolds68's Avatar
Sent you a PM
Old Jul 2, 2012 | 06:12 AM
66400's Avatar
Only 68 Cutlass, full size 88 and 98 are direct interchange. Toro is not the same.
Henry
Old Jul 2, 2012 | 06:19 AM
Octania's Avatar
"402030 RH
402031 LH
HINGE, Hood Hinge HH; pn prev. 401600 RH
1968 exc. Toro; see SPRING #574802 for F85"
a trick is to use 1st gen camaro/firebird hood hinges on a 68 cutlass. They bolt on and open the hood more.
Use hinges from a 68 Firebird... bolt right up to the 68 fenders and open higher than the Olds hinges for 68.
or...
https://classicoldsmobile.com/forums...rting-out.html
Old Jul 2, 2012 | 06:22 AM
66400's Avatar
No interchange at all between A bodies of that era.
68 Cutlass does not interchange with any other year Cutlass or any other GM A body car. Note the 68 uses 3 bolts to attach hinge to hood. 2 bolts attach hinge to fender.
Interchange '68 Cutlass, '68 Olds 88, '68 Olds 98.
Henry
Old Jul 2, 2012 | 06:25 AM
allyolds68's Avatar
Does anyone have first hand knowledge this actually works. There was a thread on ROP about it but the poster never said whether it worked or not.
I can tell you from first hand experience that the 69 hinges on a multi pattern 68-69 fender are not a direct fit. The bolt pattern for the HOOD is not the same on a 68 hood as it is on the 69 hood. They are very close. You have to elongate (I can't remember if it's a shorter or longer spacing) the holes in the 69 hinges to fit the 68 hood. As Henry has noted above, the 68 hinge has three bolts to attach the hood. I'm pretty sure the 69 hinge only had 2 holes
Old Jul 2, 2012 | 08:48 AM
jensenracing77's Avatar
i think i have a hinge for one side. i would have to double check to be sure that is what it is from. it is missing the spring. if interested $15 + shipping
Old Jul 2, 2012 | 09:30 AM
Oldsdruid
Was the question about hood hinges or door hinges? I answered for door hinges.
Old Jul 2, 2012 | 12:17 PM
sorry, i was assuming hood hinges?
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
cutlassefi
Nov 28, 2013 12:08 PM
auto_editor
Jul 10, 2011 11:20 AM
Wasted
Feb 13, 2009 03:38 PM
Aussie67Delta88Custom
Brakes/Hydraulic Systems
Oct 12, 2008 12:16 PM
