Decided to take some pic's of the typically important engine, trans rear end numbers
Old Apr 15, 2018 | 05:27 PM
capstoneclub's Avatar
today. Just beside where the distributor shaft insets into the rear center area of the engine, I noticed the numeral 3 and what I assume is the corresponding julian numerals 276. Do these numbers combine to show the year and day of manufacture for the engine block (my car is a 70-442)? Thx in advance
Old Apr 15, 2018 | 05:44 PM
rcorrigan5's Avatar
Randy C.
I would say no. In my experience, the Olds engine blocks, heads, water pump, and so forth, only have up to 3 julian date numbers to show what day of the year the piece was manufactured. In the case of *276* for your '70 4-4-2, that would be the 276th day of 1969 that the block was manufactured.
Randy C.
Old Apr 15, 2018 | 06:53 PM
I did not communicate correctly.
the numeral 3 is above the 276 date code (actually right above the numerals 27)? Does the 3 represent third year that the 455 was manufactured (1968, 1969 & 1970)?
Old Apr 15, 2018 | 06:58 PM
Here is the picture
Old Apr 15, 2018 | 07:01 PM
Once more
Old Apr 15, 2018 | 09:54 PM
70W-32's Avatar
might designate which shift. there are more casting numbers in the bellhousing area,but the trans block the view. dont forget to snap the vin derivitive stamped on the block and trans.
Old Apr 16, 2018 | 04:01 AM
zeeke's Avatar
I see no pics on my end. If you hit the yellow box that looks like mountains you can download a picture right out of your files. It only took me a few years to figure it out.
Old Apr 16, 2018 | 06:37 AM
I doubt it. Most likely it indicates Oldsmobile division (3) The blocks and intakes were investment cast from sand molds, so i doubt it would be the mold number either.
Old Apr 16, 2018 | 07:20 AM
Pic
Old Apr 16, 2018 | 08:11 AM
None of your pictures are coming through
Old Apr 16, 2018 | 10:14 AM
Old Apr 16, 2018 | 10:18 AM
Odd, but I see on my end once logged into CO from my iPhone or laptop
Hopefully the last time was the charm
pogo69
Oct 2, 2016 08:29 AM
pogo69
Oct 17, 2014 04:24 PM
Mark71
Nov 14, 2011 11:26 AM
64starfire
Apr 12, 2009 06:50 PM
